Code warrior 9.2 installation error
2,618 次查看
maheshwarreddy
Hai ,
Thank you for the reply . i installed the code warrior mobile gt 9.2 but while installing its giving the error .I continued but after opening the IDE if i create a project when i compiled that time it is error as below.
error unable to call the command line tool. check your path environmental variable.
find the below attachment.
3 回复数
2,488 次查看
maheshwarreddy
Hai Pavel ,
               Thank you for the reply . We are using the code warrior 9.2 version in this version, we are not getting the  mpc5125  device while creating the project .Can you please help us in this regards.
2,488 次查看
Pavel
Press "OK" and installing will be proceeded.
Pavel Chubakov
2,488 次查看
maheshwarreddy
Hai Pavel ,
