Access timeout error while programming UBOOT
prakharm
We are using T1022 Processor. It is hard coded with 9-E.
Getting access timeout error while programming UBOOT with the help of Lauterbach.
At FLASHFILE.Target command it shows getting FLASHFILE info then access timeout error occurs.
yipingwang
It seems that this is the issue of the tool, please contact https://www.lauterbach.com/
rweiss
Contributor V
Please contact Lauterbach support at https://support.lauterbach.com/ to get help on this issue.
