how to use FlexGUI for FS85 / FS84 Evaluation Tools ??
JINN
i downloaded FlexGUI for FS85 / FS84 Evaluation Tools.
but i cant find .exe File so i cant run this SW.
how can i use and run that tool??
and then, i should download " MC33FS8530" PMIC.
Could you explain for me how to do that ??
thank you so much.
Tags (4)
TomasVaverka
Please follow the instructions given in the User Manual of the corresponding evaluation board.
Here for example from the UM11157 (sign in required to be able to download it):
From my PC:
Tomas
JINN
Thank you for supporting me.
i watch your reply, and i search flexgui-app-spm File.
but, when i click that file,  just run "window command" and then automatically closed that.
in your case, when you click flexgui-app-spm file, run " Flexgui-launcher ".
how can i run " Flexgui-launcher" ??
and when i connect usb with target, i cant find "Secon flex gui" in my computer's device manager.
TomasVaverka
There was another customer facing most likely the same issue, please take a look at the following thread where my colleague provided instructions to fix it.
https://community.nxp.com/t5/Power-Management/FlexGUI-for-FS85-FS84-Evaluation-Tools-quot-bat-quot-f...
I hope it helps.
Tomas
