TEA1716T Undervoltage Case
1,397 次查看
kmesne
Hi, I was reading both the datasheet and application note of the "TEA1716T" . For the undervoltage situations it says switching is stopped for PFC and HBC part. But what is stopped means exactly? Does it connect that pins to the ground or applies some negative voltage or what ? I couldn see any clarification about this topic in both documents and would be happy if you enlighten me.
1,352 次查看
brian14
Hi @kmesne,
Thank you for contacting NXP Support!
I noticed that you have another community thread for this issue, please refer to your other thread replied by my colleague, in order to avoid confusion with the information.
Have a great day!
1,388 次查看
kmesne
I am looking for a value something like V(OLS) : UVLO saturation. Which gives the voltage value of the gate input when there is an undervoltage
