TEA1716 problem
TEA1716 problem
ravindrabalsara
we have developed led driver solution 60v,3A based upon silergy IC SSL4120T,but SSL4120t not available for production,it get absoluted.we are planning to replace it by TEA1716T resonance IC.we have replace ic by TEA1716,but we have not getting output ,led getting flikkered o/p.we want use TEA1716 as led driver CC mode.please let us know anything need change in circuit diagramme.i found TEA1716 is pin compatible with SSL4120T.kindly help us to resolve the issue.
guoweisun
Have already send to you case about reply!
