ScriptGUI and EVBMA6X02BMU
9件の閲覧回数
lukap
Hi ,
We have one question regarding ScriptGUI and its compatibility with the newer BMUs.
Recently we got the new evaluation board (EVBMA6X02BMU) and we got recommended to combine Complex Device Drivers with it. There is available AUTOSAR software for it ( BMS GEN2 SDK AUTOSAR 4.4 R21-11 Version 0.9.1 ), but as we started using this software it seems that it is an overkill for our current use cases. We would benefit more if we could combine the mentioned evaluation board with the ScriptGUI.
Is the EVBMA6X02BMU compatible with the ScriptGUI? It has a BMX6X02 communication gateway on it.
Our guess is that we need to download specific firmware to the EVB's MCU and connect the board to PC with FDTI cable.
0 返答(返信)
