PF8121 Driver
3,885件の閲覧回数
david_ochs1
Are there Linux and U-boot drivers available for the PF8121? We are planning to use it for a new board with an i.MX8M Mini running Linux, and we need to adjust some settings over I2C.
Dave
3,720件の閲覧回数
guoweisun
HI
We don't have such driver for customer but you can download it from third part:
https://boundarydevices.com/nitrogen8-family/
3 返答(返信)
3,721件の閲覧回数
guoweisun
HI
3,720件の閲覧回数
david_ochs1
Thanks for the quick response. I see that they're using a PF8x00 driver; I presume that's the one you're referring to? That one looks like it should also work for the PF8121, correct?
3,720件の閲覧回数
guoweisun
You are correct!
