PF8100/8200 latest material
enriquemontero
May you please reconfirm below links correspond to thelatest documentation as of 24Sep20,
In case there is a any newer documentation, let me know:
- Datasheet. Reconfirmation that the one currently on external web are the latest:
     https://www.nxp.com/docs/en/data-sheet/PF8100_PF8200.pdf
- Errata:
     https://www.nxp.com/docs/en/errata/ES_PF8100_PF8200_2.pdf
- Hardware Design Guidelines:
     AN12286, Hardware design guidelines for PF81/82 PMIC family- Application note
- Evaluation Board for PF8100 y PF8200 with schematics, lay out and other docs.
     https://www.nxp.com/products/power-management/pmics-and-sbcs/pmics/12-channel-power-management-integ...
Any other material we should consider besides this?
Thanks and Regards
Enrique Montero
reyes
Hi Enrique,
Correct, latest version of the documents can be found in external nxp website in the links you sent.
-Datasheet
Latest datasheet is revision 9.0 - 19 November 2019: https://www.nxp.com/docs/en/data-sheet/PF8100_PF8200.pdf
-Errata:
Latest Errata is revision Rev. 2 — 11 August 2020: https://www.nxp.com/docs/en/errata/ES_PF8100_PF8200_2.pdf
- Hardware design guidelines:
AN12286 latest version is Rev. 2.0 — 14 January 2019: https://www.nxp.com/docs/en/application-note/AN12286.pdf
And you can find the Functional Safety Manual V1.0 and the PF8200_FMEDA_customer V2.1 in DocStore.
There is an internal NXP community dedicated to Power Management devices, you can contact Dennis Zeng in can you want to join this internal community: [email protected]
Jose
reyes
Hi Enrique,
-Datasheet
-Errata:
Jose
