PF4210 configuration difference
已解决
跳至解决方案
3,500 次查看
m_c
Senior Contributor I
In chapter 10.1 startup, it said The PF4210 can be configured to start up from either the internal OTP configuration, or with a hard coded configuration built into the device. What is the difference between 1) hard coded configuration 2) internal OTP configuration 3) default configuration and 4) preprogrammed OTP configuration?
标签 (1)
标记 (1)
1 解答
3,335 次查看
guoweisun
Hi M.C
Please note that hard coded configuration is same with default configuration .
 preprogrammed OTP configuration is same with internal OTP configuration.
在原帖中查看解决方案
1 回复
3,336 次查看
guoweisun
Hi M.C
