PCA9451A / imx93 battery backup for RTC
2,085 次查看
arekkaras
does the PCA9451A support battery backup for NVCC_BBSM_1V8 voltage domain ?
Is there any application note/recommendation how to keep RTC running on iMX93 while there is no external 5V power supply connected to PMIC?
Arkadiusz
2,047 次查看
arekkaras
Hi Guoweisun,
It was my first idea, but I realised that from this input also other LDO's are powered so it doesn't seem to be best solution.
Additionally, I am using 32kHZ RTC clock from PMIC for iMX93 as well, so in order to get this clock running IMHO whole PMIC needs to be powered ?
Arkadiusz
2,033 次查看
guoweisun
Yes,correct!
2,065 次查看
guoweisun
Do you mean that use battery as input of LDO1 to get the backup power?
