PCA9450 power dissipation
2,134 次查看
Yakovs
How to calculate the total Power Dissipation on the PCA9450 when powering the MIMX8ML8DVNLZAB? Is there typical PD or maybe you have a tool to calculate it?
3 回复数
2,118 次查看
Yakovs
Thank you,
I actually understand how to calculate the PD, but I'm at the very beginning of the design phase and need to estimate the calculated PD. So I was hoping you have a typical PCA9450 PD with a typical iMX8 power consumption.
2,100 次查看
ErikaC
Hello, Sorry for the delay in replying, I have confirmed with the application team and we do not have a tool to calculate it. We apologize for the inconvenience this may cause you.
2,123 次查看
ErikaC
PCA9450 integrates 6*DCCs and 5*LDOs, they work as one chip.
There are some methods to calculate the power Dissipation from each regulators to get the total power dissipation to get a ΔT with thermal resistors.
For DC-DC, Power Dissipation = Pinput * (1-efficiency);
For LDO, Power Dissipation = (Vin-Vout)*Iout;
then we can get the total power dissipation(P) of all the regulators, P*Rth(ja) = ΔT, Tambient + ΔT should be smaller than max Junction temperature (125℃)
Hope it helps,
Regards.
