MMPF0100 PMIC - SW4 VTT design reference
已解决
跳至解决方案
5,397 次查看
henrikalexander
Is there any design reference for MMPF0100 were SW4 is used as VTT and SW3 is hooked up to power DRAM.
1 解答
5,188 次查看
reyes
You need to connect SW4IN to SW3Lx (SW3FB) and connect SW4Lx (SW4FB) to VTT.
Jose
在原帖中查看解决方案
4 回复数
5,188 次查看
reyes
Unfortunately, there is no reference design for MMPF0100 were SW4 is used as VTT and SW3 is hooked up to power DRAM, however, this is very easy to design since SW4 regulator can be used in a VTT tracking mode for DDR memory termination, in this mode, SW4 output voltage automatically tracks half of SW3A output voltage (which would be used to provide VCC for the DDR). VTT mode can be configured by use of VTT bit in the OTP_SW4_CONFIG register.
Jose
5,188 次查看
henrikalexander
Yes so much I understand, what i need to know is:
1. Do a need to connect SW4IN to DDR voltage. (My Guess is NO)
2. Shall i connect SW4FB to VTT. (My guess is YES)
5,189 次查看
reyes
Jose
5,188 次查看
henrikalexander
Thx for the support.
