MC33PT2000 use issues
2,612 次查看
yuanguangyi
We are a company in Pudong. We are using your MC33PT2000 chip, but we have some problems in the process of using it.
1. The new board is abnormal when PT2000 is used.
2. PT2000 has not been able to increase the pressure. Or it can't go up after loading.
3. PT2000 has the problem of burning chips, and this problem has occurred more than once.
4. Our contact information is 150-0025-6530. Is it convenient to contact us?
5. my e-mail is [email protected]
我们是浦东的一家公司,我们正在使用贵司的MC33PT2000这颗芯片,但是我们在使用过程中出现一些问题。
1.新回来的板子,用着用着PT2000就不正常了。
2.PT2000出现升压升不上去。或者加了负载以后升不上去。
3.PT2000出现烧芯片问题,而且不止一次出现这个问题。
4.我们的联系方式是150-0025-6530,请问方便联系我们一下吗?
5.我的邮箱是 [email protected]
谢谢!
标记 (1)
2 回复数
2,401 次查看
TomasVaverka
Hi Quangyi,
Couple of questions to better understand the issue you are facing:
>> What is the difference between your old and new board? Can you share their schematics? Does the issue appear on all your new boards?
>> What is actually the load and what pre-driver/MOSFET are you talking about? Do you have any oscilloscope plots illustrating unexpected behavior? Can you share your requirements/settings?
>> What is the occurrence rate and is the PT2000 or an external MOSFET burned?
Tomas
2,401 次查看
yuanguangyi
hello,Tomas:
 ----  this is frist time we use PT2000.
 ---- i think the problem is feedback of vboost,but i don't know how to debug .
my email is [email protected],can we talk with email?
---- yes , we burned mos one time
