MC33PF8100
MC33PF8100
jianxin
Hi, NXP team~
I am looking for power solutions that can support CV22(QM) and LPDDR4.
Can the four models below be used to support CV22(QM) and LPDDR4? If not, can you recommend the right model?
And can MC33PF8100A0ES be used to support LPDDR4?
What is the difference between MC33PF8100EPES, MC33PF8100EQES and MC33PF8100FJES?
Best Regards.
jianxin
Hi, guowei
Thank you for you reply, I also checked the application note < AN13272>,
it says that the models below can support CV22 and LPDDR4, is it also right?
Best Regards.
guoweisun
Yes,I think so!
guoweisun
You can select below:
