Interface SBC FS6500 (kit) with the MPC5643L
2,716 次查看
raghurajappa
I am trying to interface SBC FS6500 (kit) with the MPC5643L (development board - XPC56XX motherboard rev.B) through SPI or CAN. I am unable to find any documentation that will assist me in interfacing. I don't expect the exact same controllers but atleast programmer's guide to interfacing the SBC with other microcontrollers would be very useful. I do see the webpage (KITFS6522LAEEVM | Evaluation Board for FS6500|NXP ). It has been useful but not enough to help me make successful interfacing. Also I do not understand how to write the register.xls file that is used as an input to the FlexGUI software tool.
Any suggestion/hint would be useful. Thank you so much.
Also another context that may or maynot be useful - I am using Simulink to program the MPC5643L. The intention now is to communicate to the SBC chip through the MPC from Simulink. But before that I would like to understand how to program the SBC as intended.
Summary - Programmer's guide OR interface guide for SBC FS65XX.
标记 (3)
1 回复
2,429 次查看
TomasVaverka
Hello Raghu,
I would recommend taking a closer look at the AN5099. Although it targets slightly different devices, it might help you with interfacing.
Regarding software, I recommend using the FS65xx driver as a reference.
Tomas
