How to disable the FS8410
WenChao
Hi,all
I'm trying to enable and disable the FS8410 by the INH siginal of the TJA1043,cause I need to make the radar sleep to save battery in some cases.but there's no ENABLE pin in the FS8410.And I want to know if there will be any power up sequence problems.
Please help me with this requirement,thanks!
BR.
WENCHAO
guoweisun
 In the rev5.0 datasheet page 15-14.1 Simplified functional state diagram
You can get from Normal-all regulator ON to stand by mode by GoTo_STBY=1 or FS_READY=0 or (VALID_WD=WAKE1=WAKE2=0)
guoweisun
WenChao
Hello,SUN
I've tried the GoTo_STBY=1 command,and i find this will make the PMIC FS8410G3ES sleep for a little time,then it would be reset immediately.I havn't find the key point until now.If there's something I've missed,please let me know,thanks!
BR.
WENCHAO
WenChao
Hi,guowei
I've find my problem,which is I didn't  make the W1DIS=1,so when the PMIC is powering down,it would wake up immediately because the PIN wake1 is connect to VSUP directly.
Sorry to bother you for this simple question.Thank you very much!
BR,
WENCHAO
