FS6513 FS0B can not be released
witness248
hi, experts
Now we are using S32K324&FS6513 for our ECU, but the FS0B of FS6513 is always low although we have invoke the release function. and I have checked below condition.
read the corresponding register:
寄存器                                           读取的值
DIAG_SF_ERR                                0xF00
SF_OUTPUT_REQUEST                  0xF81
BIST                                               0xF0F
any idea from your side?
guoweisun
RELEASE FSXB的步骤再确认下,看起来像这一步没有做对,我们有这种参考程序:
fs65_status_t FS65_ReleaseFSx(fs65_fsxb_release_t fsOutput)
fs65_status_t status = fs65StatusOk; /* Status variable. */
uint8_t writeData; /* Data to be written. */
uint8_t wdSeed; /* Watchdog seed value. */
FS_ASSERT((fsOutput == fs65ReleaseFs0b) || (fsOutput == fs65ReleaseFs1b) || \
(fsOutput == fs65ReleaseFs0bFs1b));
#ifdef FS65_FEATURE_FS1B
status = FS65_CheckFS1B();
if (status != fs65StatusOk)
return status;
#endif
status = FS65_CheckVAUX();
return status;
/* Get actual LFSR state. */
status = FS65_WD_ReadChallengeToken(&wdSeed);
return status;
/* Prepare release word. */
switch (fsOutput)
case fs65ReleaseFs0b:
writeData = (uint8_t)fs65ReleaseFs0b;
writeData |= (wdSeed & (1U << 4U) ? 0x00U : 0x01U);
writeData |= (wdSeed & (1U << 3U) ? 0x00U : 0x02U);
writeData |= (wdSeed & (1U << 2U) ? 0x00U : 0x04U);
writeData |= (wdSeed & (1U << 1U) ? 0x00U : 0x08U);
writeData |= (wdSeed & (1U << 0U) ? 0x00U : 0x10U);
break;
case fs65ReleaseFs1b:
writeData = (uint8_t)fs65ReleaseFs1b;
writeData |= (wdSeed & (1U << 7U) ? 0x00U : 0x01U);
writeData |= (wdSeed & (1U << 6U) ? 0x00U : 0x02U);
writeData |= (wdSeed & (1U << 5U) ? 0x00U : 0x04U);
writeData |= (wdSeed & (1U << 4U) ? 0x00U : 0x08U);
writeData |= (wdSeed & (1U << 3U) ? 0x00U : 0x10U);
break;
case fs65ReleaseFs0bFs1b:
writeData = (uint8_t)fs65ReleaseFs0bFs1b;
break;
#endif
default:
return fs65StatusError;
return FS65_WriteRegister(FS65_FS_RELEASE_FSXB_ADDR, writeData, NULL);
guoweisun
HI
我没办法粘贴图片,从normal 状态转换到release FSXB 需要满足下面的的条件:
1:FLT_err_count=0
2:ABISTx ok
3:FS_OUT ok
你这个背景是第一次release FSXB还是说遇到了fault以后FSXB拉低了然后你想把他置高?
witness248
hi,
我是第一次release FS0B。此外FS寄存器配置如下:
INIT_FS1B_TIMING_ADR, 0x65
BIST_ADR, 0x65
INIT_SUPERVISOR_ADR, 0x0C
INIT_FAULT_ADR, 0x0C
INIT_FSSM_ADR, 0x0C
INIT_SF_IMPACT_ADR, 0x0C
WD_WINDOW_ADR, 0xf3
SF_OUTPUT_REQUEST_ADR, 0x0C
INIT_VCORE_OVUV_IMPACT_ADR,0x0C
INIT_VCCA_OVUV_IMPACT_ADR, 0x0C
INIT_VAUX_OVUV_IMPACT_ADR, 0x0C
FS1B未使用,为悬空状态。
guoweisun
1:FLT_err_count=0
2:ABISTx ok
3:FS_OUT ok
这些状态都对吗?上面的这些状态?
witness248
1:FLT_err_count=0
这个count,只在第一次喂狗前,为0,后续都是不为0。所以我的release FS0B只能被调用一次(放到了喂狗函数里)。
2:ABISTx ok
这个是OK的
3:FS_OUT ok
怎么判断OK?是通过读取RELEASE_FSxB吗?
guoweisun
影响faulterrorcounter的因素看附件我列出来了,需要你一个个排查。
witness248
hi,吴工
感谢回复。我现在的进展是Fault error count为0了,然后写入RELEASE_FSxB_ADR,读出来的值确是0x8F81, 为SPI ERR,这个可能的原因有哪些?
guoweisun
return status;
#endif
return status;
return status;
switch (fsOutput)
break;
break;
break;
#endif
default:
guoweisun
1:你好像是有fault一直,所以faulterrorcounter不是0.
2:the "FS_OUT write OK" means, that the right command was sent to the RELEASE_FSxB register. If the right command was sent there by the MCU, the FS0B is released. Same for the FS1B if the FS6500 have this pin.
dbddbd
你好,我遇到了同样的问题,请问你是如何解决的,我检查了上述表格中造成错误计数器增加的可能性,但是通过读寄存器结果全是无错误,但是此时读错误寄存器的值,是1,不是0,长时间的争取喂狗,也没有消除。
witness248
你好,如下条件需要满足
•ABIST2_FS1B_OK=1 if part number with FS1B
•ABIST2_VAUX_OK=1 except if VAUX_FS_OV_1:0=VAUX_FS_UV_1:0=”00”
•Fault is removed
•Fault error counter must be at ’0’
•Close the S1 switch if FS1B backup delay was engaged (FS1B_DLY_DRV bit = 1)
•RELEASE_FSxB register must be filled with the right value
dbddbd
你好,非常感谢回复,电源芯片中我未使用FS1B和VAUX,VAUX通过INIT_VAUX_OVUV_IMPACT和REG_MODE这两个寄存器关闭其功能,并且通过读取BIST寄存器发现,LBIST_OK、ABIST2_FS1B_OK、ABIST2_VAUX_OK、ABIST1_OK,都显示OK,但此时错误计数器的值一直为1,并且读到VAUX一直欠压,手册也明确表示当VAUX未使用时,Vaux_UVflag is set and cannot be cleared。所以一直没找到办法去消除错误计数器。如果方便的话可以给我您的例程代码吗?非常感谢!
witness248
你好,你当前设置窗口狗的窗口长度是多少?喂狗周期多少?断开调试和连接调试器,现象都是一样的吗?附件是我之前找的例程,供参考。
dbddbd
  • 你好,感谢回复,这个代码我正在使用,但还是无法实现释放FS0B的效果,喂狗窗口长度是512ms,喂狗时间是在它的4分之3处,debug下也不行,调试下如果定时喂狗,发现错误计数器的值一直在加,最后到6,不定时喂狗,错误计数器的值为0,但是BIST中的ABIST2_VAUX_OK一直是错的,FS0B也一直是低电平。感觉跟想像的不一样。您那边最后是怎么消除那个错误计数器的值呢
witness248
1) 首先BIST中的ABIST2_VAUX_OK一直都是错的,这个需要排查下,我的BIST_ADR配置的是0x65.
2) 我是在喂狗函数里,读取DIAG_SF_ERR,当FLT_ERR_2:0为0时,再去释放FS0B。每连续7次喂狗,错误count会递减。
%3CLINGO-SUB%20id%3D%22lingo-sub-2056732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%20experts%3C%2FP%3E%3CP%3ENow%20we%20are%20using%20S32K324%26amp%3BFS6513%20for%20our%20ECU%2C%20but%20the%20FS0B%20of%20FS6513%20is%20always%20low%20although%20we%20have%20invoke%20the%20release%20function.%20and%20I%20have%20checked%20below%20condition.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22witness248_0-1741238896134.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F326932iAB5717D063BDB0F7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22witness248_0-1741238896134.png%22%20alt%3D%22witness248_0-1741238896134.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eread%20the%20corresponding%20register%3A%3C%2FP%3E%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%E8%AF%BB%E5%8F%96%E7%9A%84%E5%80%BC%3C%2FP%3E%3CP%3E%3CSTRONG%3EDIAG_SF_ERR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200xF00%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESF_OUTPUT_REQUEST%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200xF81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EBIST%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200xF0F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eany%20idea%20from%20your%20side%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%9D%A1%E4%BB%B6%E9%9C%80%E8%A6%81%E6%BB%A1%E8%B6%B3%3C%2FP%3E%3CP%3E%E2%80%A2ABIST2_FS1B_OK%3D1%20if%20part%20number%20with%20FS1B%3CBR%20%2F%3E%E2%80%A2ABIST2_VAUX_OK%3D1%20except%20if%20VAUX_FS_OV_1%3A0%3DVAUX_FS_UV_1%3A0%3D%E2%80%9D00%E2%80%9D%3CBR%20%2F%3E%E2%80%A2Fault%20is%20removed%3CBR%20%2F%3E%E2%80%A2Fault%20error%20counter%20must%20be%20at%20%E2%80%990%E2%80%99%3CBR%20%2F%3E%E2%80%A2Close%20the%20S1%20switch%20if%20FS1B%20backup%20delay%20was%20engaged%20(FS1B_DLY_DRV%20bit%20%3D%201)%3CBR%20%2F%3E%E2%80%A2RELEASE_FSxB%20register%20must%20be%20filled%20with%20the%20right%20value%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2058348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2058348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ERELEASE%20FSXB%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%86%8D%E7%A1%AE%E8%AE%A4%E4%B8%8B%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E8%BF%99%E4%B8%80%E6%AD%A5%E6%B2%A1%E6%9C%89%E5%81%9A%E5%AF%B9%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%E8%BF%99%E7%A7%8D%E5%8F%82%E8%80%83%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Efs65_status_t%20FS65_ReleaseFSx(fs65_fsxb_release_t%20fsOutput)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Efs65_status_t%20status%20%3D%20fs65StatusOk%3B%20%2F*%20Status%20variable.%20*%2F%3CBR%20%2F%3Euint8_t%20writeData%3B%20%2F*%20Data%20to%20be%20written.%20*%2F%3CBR%20%2F%3Euint8_t%20wdSeed%3B%20%2F*%20Watchdog%20seed%20value.%20*%2F%3C%2FP%3E%0A%3CP%3EFS_ASSERT((fsOutput%20%3D%3D%20fs65ReleaseFs0b)%20%7C%7C%20(fsOutput%20%3D%3D%20fs65ReleaseFs1b)%20%7C%7C%20%5C%3CBR%20%2F%3E(fsOutput%20%3D%3D%20fs65ReleaseFs0bFs1b))%3B%3C%2FP%3E%0A%3CP%3E%23ifdef%20FS65_FEATURE_FS1B%3CBR%20%2F%3Estatus%20%3D%20FS65_CheckFS1B()%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20fs65StatusOk)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20status%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%23endif%3C%2FP%3E%0A%3CP%3Estatus%20%3D%20FS65_CheckVAUX()%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20fs65StatusOk)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20status%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%2F*%20Get%20actual%20LFSR%20state.%20*%2F%3CBR%20%2F%3Estatus%20%3D%20FS65_WD_ReadChallengeToken(%26amp%3BwdSeed)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20fs65StatusOk)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20status%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%2F*%20Prepare%20release%20word.%20*%2F%3CBR%20%2F%3Eswitch%20(fsOutput)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ecase%20fs65ReleaseFs0b%3A%3CBR%20%2F%3EwriteData%20%3D%20(uint8_t)fs65ReleaseFs0b%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%204U)%20%3F%200x00U%20%3A%200x01U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%203U)%20%3F%200x00U%20%3A%200x02U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%202U)%20%3F%200x00U%20%3A%200x04U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%201U)%20%3F%200x00U%20%3A%200x08U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%200U)%20%3F%200x00U%20%3A%200x10U)%3B%3CBR%20%2F%3Ebreak%3B%3CBR%20%2F%3E%23ifdef%20FS65_FEATURE_FS1B%3CBR%20%2F%3Ecase%20fs65ReleaseFs1b%3A%3CBR%20%2F%3EwriteData%20%3D%20(uint8_t)fs65ReleaseFs1b%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%207U)%20%3F%200x00U%20%3A%200x01U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%206U)%20%3F%200x00U%20%3A%200x02U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%205U)%20%3F%200x00U%20%3A%200x04U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%204U)%20%3F%200x00U%20%3A%200x08U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%203U)%20%3F%200x00U%20%3A%200x10U)%3B%3CBR%20%2F%3Ebreak%3B%3CBR%20%2F%3Ecase%20fs65ReleaseFs0bFs1b%3A%3CBR%20%2F%3EwriteData%20%3D%20(uint8_t)fs65ReleaseFs0bFs1b%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%207U)%20%3F%200x00U%20%3A%200x01U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%206U)%20%3F%200x00U%20%3A%200x02U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%202U)%20%3F%200x00U%20%3A%200x04U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%201U)%20%3F%200x00U%20%3A%200x08U)%3B%3CBR%20%2F%3EwriteData%20%7C%3D%20(wdSeed%20%26amp%3B%20(1U%20%26lt%3B%26lt%3B%200U)%20%3F%200x00U%20%3A%200x10U)%3B%3CBR%20%2F%3Ebreak%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Edefault%3A%3CBR%20%2F%3Ereturn%20fs65StatusError%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3Ereturn%20FS65_WriteRegister(FS65_FS_RELEASE_FSXB_ADDR%2C%20writeData%2C%20NULL)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056814%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056814%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E1%3A%20You%20seem%20to%20have%20a%20fault%2C%20so%20the%20faulterrorcounter%20is%20not%200.%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorguoweisun_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%3E2%EF%BC%9Athe%20%22FS_OUT%20write%20OK%22%20means%2C%20that%20the%20right%20command%20was%20sent%20to%20the%20RELEASE_FSxB%20register.%20If%20the%20right%20command%20was%20sent%20there%20by%20the%20MCU%2C%20the%20FS0B%20is%20released.%20Same%20for%20the%20FS1B%20if%20the%20FS6500%20have%20this%20pin.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorguoweisun_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditorguoweisun_2%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056752%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056752%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorguoweisun_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3EI%20can't%20paste%20the%20image.%20To%20switch%20from%20normal%20state%20to%20release%20FSXB%20needs%20to%20meet%20the%20following%20conditions%3A%3C%2FP%3E%0A%3CP%3E1%3A%20FLT_err_count%20%3D%200%3CBR%20%2F%3E%202%3A%20ABISTx%20ok%3CBR%20%2F%3E%203%3A%20FS_OUT%20ok%3C%2FP%3E%0A%3CP%3EIs%20this%20your%20first%20time%20releasing%20FSXB%20or%20did%20you%20encounter%20a%20fault%20and%20FSXB%20was%20pulled%20down%20so%20you%20want%20to%20raise%20it%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056826%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056826%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20listed%20the%20factors%20that%20affect%20faulterrorcounter%20in%20the%20attachment.%20You%20need%20to%20check%20them%20one%20by%20one.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056768%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056768%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E1%3A%20FLT_err_count%20%3D%200%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E2%3A%20ABISTx%20ok%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E3%3A%20FS_OUT%20ok%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAre%20these%20states%20correct%3F%20The%20above%20states%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056766%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056766%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EThis%20is%20my%20first%20time%20to%20release%20FS0B.%20In%20addition%2C%20the%20FS%20register%20configuration%20is%20as%20follows%3A%3C%2FP%3E%3CDIV%3E%3CSPAN%3EINIT_FS1B_TIMING_ADR%2C%200x65%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EBIST_ADR%2C%200x65%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_SUPERVISOR_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_FAULT_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_FSSM_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_SF_IMPACT_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWD_WINDOW_ADR%2C%200xf3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESF_OUTPUT_REQUEST_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_VCORE_OVUV_IMPACT_ADR%2C0x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_VCCA_OVUV_IMPACT_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINIT_VAUX_OVUV_IMPACT_ADR%2C%200x0C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFS1B%20is%20not%20used%20and%20is%20in%20floating%20state.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067320%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067320%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHello%2C%20thank%20you%20very%20much%20for%20your%20reply.%20I%20did%20not%20use%20FS1B%20and%20VAUX%20in%20the%20power%20chip.%20VAUX%3C%2FSPAN%3E%20%3CSPAN%3Eturned%20off%20its%20function%20through%20the%20two%20registers%20INIT_VAUX_OVUV_IMPACT%20and%20REG_MODE.%20By%20reading%20the%20BIST%20register%2C%20I%20found%20that%20LBIST_OK%2C%20ABIST2_FS1B_OK%2C%20ABIST2_VAUX_OK%2C%20and%20ABIST1_OK%20all%20showed%20OK%2C%20but%20the%20value%20of%20the%20error%20counter%20was%20always%201%2C%20and%20VAUX%20was%20always%20undervoltage.%20The%20manual%20also%20clearly%20stated%20that%20when%20VAUX%20was%20not%20used%2C%20Vaux_UVflag%20was%20set%20and%20could%20not%20be%20cleared.%20So%20I%20have%20not%20found%20a%20way%20to%20eliminate%20the%20error%20counter.%20If%20it%20is%20convenient%2C%20can%20you%20give%20me%20your%20routine%20code%3F%20Thank%20you%20very%20much!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2065552%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2065552%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20have%20the%20same%20problem.%20How%20did%20you%20solve%20it%3F%20I%20checked%20the%20possibility%20of%20increasing%20the%20error%20counter%20in%20the%20above%20table%2C%20but%20the%20result%20of%20reading%20the%20register%20was%20all%20error-free.%20However%2C%20the%20value%20of%20the%20error%20register%20at%20this%20time%20was%201%2C%20not%200.%20I%20tried%20to%20feed%20the%20dog%20for%20a%20long%20time%2C%20but%20it%20did%20not%20eliminate%20the%20problem.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056806%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056806%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E1%3A%20FLT_err_count%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20count%20is%200%20only%20before%20the%20first%20feeding%20of%20the%20dog%2C%20and%20it%20is%20not%200%20afterwards.%20So%20my%20release%20FS0B%20can%20only%20be%20called%20once%20(put%20in%20the%20feeding%20dog%20function).%3CBR%20%2F%3E%20%3CSPAN%3E2%3A%20ABISTx%20ok%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20OK%3CBR%20%2F%3E%20%3CSPAN%3E3%3A%20FS_OUT%20ok%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHow%20to%20judge%20OK%3F%20Is%20it%20by%20reading%20RELEASE_FSxB%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2057470%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2057470%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%EF%BC%8C%E5%90%B4%E5%B7%A5%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply.%20My%20current%20progress%20is%20that%20the%20fault%20error%20count%20is%200%2C%20and%20then%20I%20write%20to%20RELEASE_FSxB_ADR%2C%20and%20the%20read%20value%20is%200x8F81%2C%20which%20is%20SPI%20ERR.%20What%20are%20the%20possible%20reasons%20for%20this%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2069092%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6513%20FS0B%20can%20not%20be%20released%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2069092%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20what%20is%20the%20window%20length%20of%20the%20window%20dog%20you%20currently%20set%3F%20What%20is%20the%20dog%20feeding%20cycle%3F%20Is%20the%20phenomenon%20the%20same%20when%20disconnecting%20the%20debugger%20and%20connecting%20the%20debugger%3F%20The%20attachment%20is%20the%20routine%20I%20found%20before%2C%20for%20reference.%3C%2FP%3E%3C%2FLINGO-BODY%3E
