FS2603B FCCU functionality
mvdv
Is the FCCU functionality available in FS2603B version?
TomasVaverka
Hello Marcel,
From the FS26 Safety Manual 3.0:
FYI, the Safety Manual as well as other documentation (Product Guidelines, FMEDA etc.) are classified as Secure Files requiring an NDA. If there is a valid NDA in place, you can download it from:
https://www.nxp.com/products/power-management/pmics-and-sbcs/safety-sbcs/safety-system-basis-chip-wi...
PS: Please make sure you are signed in to nxp.com. If you do not see the FS26 Safety Manual, please click on "Request additional access" or edit your secure access rights by going to My NXP > Profile. For more information about secure access rights, please refer to this document.
Tomas
mvdv
Thank you for the info. Yes I have access to the secure files.
The most confusing is that FCCU monitoring is OPTIONAL for FS26xyB (table 5 of this safety manual "SM616130-FS26 Safety Manual 3.0(3.0).pdf" )
Same as in Table 1 of "DS616030-FS26 Product Datasheet 3.0(3.0).pdf"
It suggests that the FCCU function can be enabled somehow, but it is not in the OTP configuration.
From your answer I conclude that there isn't any reaction on the state of the FCCU pins in the FS2603B device.
