FS26 PMIC VPRE
FS26 PMIC VPRE
3,029件の閲覧回数
GNANAPANDI
Hai NXP Team,
we design Motor Controller using S32K311 Microcontroller With FS26 PMIC,
We config FS 26 PMIC as Direct Voltage from Battery voltage to VSUP pin. we don't used VBST connection so VBST_FB, VBST_ISL, VBST_ISH connected to GND as per datasheets.
Now only we get voltage VDIG =1.5V, VBOS =5.0V, VPRE =0V
what we do to get VPRE voltage ???
5 返答(返信)
3,004件の閲覧回数
GNANAPANDI
MFS2613AMD3D and MFS2613AMD6D
3,001件の閲覧回数
guoweisun
MFS2613AMDA3AD and MFS2613AMDA6AD,right? If yes they are frond-end configuration you need refer to below circuit:
2,980件の閲覧回数
GNANAPANDI
if this PMIC , will it support direct power supply to VSUP without Front end mode (without VBST) configuration
2,961件の閲覧回数
guoweisun
No,for these two parts had done OTP with the frond-end model which doesn't support this.
3,006件の閲覧回数
guoweisun
What's your detail FS26 part number?
