Clarifications required for SBCFS2613 Main state Faults reaction
310件の閲覧回数
Sivahari
Hi NXP,
Could you please confirm whether a default fail-safe reaction (assertion of FSXB and RSTB) is configured for the following faults in the respective registers?
  • M_TSD_FLG
  • M_REG_FLG
  • M_VSUP_FLG
Since the faults in the above registers are configured to provide an INTB indication, clarification is required on whether they also have any default fail-safe reaction, such as assertion of FSXB and/or RSTB.
Sivahari G
3 返答(返信)
274件の閲覧回数
RafaR
Hello Sivahari
Good day!
I couldn't identify exactly which PN you were referring to, but in general this applies to all versions of FS26.
In summary, the flags in M_TSD_FLG, M_REG_FLG, and M_VSUP_FLG are interrupt sources by default. A fail-safe reaction such as FS0B (FSXB) and/or RSTB assertion is not automatically associated with the flag itself and depends on the corresponding fail-safe configuration, with TSD faults being an explicit example that can be configured to escalate into Deep Fail Safe.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
270件の閲覧回数
Sivahari
Hi RafaR,
I couldn't identify exactly which PN you were referring to?
I am using MFS2613AMDA6.
A fail-safe reaction such as FS0B (FSXB) and/or RSTB assertion is not automatically associated with the flag itself and depends on the corresponding fail-safe configuration.
Yes, absolutely for all regulators UV/OV fault has failsafe configuration registers "FS_I_OVUV_SAFE_REACTION1" and " FS_I_OVUV_SAFE_REACTION2 ". But Is there any provision to configure fail-safe reaction for all regulator Over Current Faults? since we have provisions to configure INTB masking/unmasking for those faults.
Example OC Faults(VBSTOV_I, VBSTOC_I, VPREOC_I, TRK1OC_I, COREOC_I)
Sivahari G
263件の閲覧回数
RafaR
Hello Sivahari
Good day!
Unfortunately, the FS26 does not have an equivalent to FS_I_OVUV_SAFE_REACTION1/2 for currents, but, all LDOs and TRKs have a current limiter, so they should remain safe even if an overclock is detected, giving you time to check it. Depending on where it originates, a different process may begin, for example, VPRE.
%3CLINGO-SUB%20id%3D%22lingo-sub-2406990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESBCFS2613%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E9%9A%9C%E5%AE%B3%E5%8F%8D%E5%BF%9C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AA%AC%E6%98%8E%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%90%84%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20%3CSTRONG%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E5%8F%8D%E5%BF%9C%3C%2FSTRONG%3E%20(%20%3CSTRONG%3EFSXB%E3%81%A8RSTB%3C%2FSTRONG%3E%E3%81%AE%E4%B8%BB%E5%BC%B5)%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EM_TSD_FLG%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EM_REG_FLG%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EM_VSUP_FLG%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%81%AF%3CSTRONG%3EINTB%E8%A1%A8%E7%A4%BA%3C%2FSTRONG%3E%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%20%3CSTRONG%3EFSXB%E3%82%84RSTB%3C%2FSTRONG%3E%E3%81%AE%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%3CSTRONG%3E%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E5%8F%8D%E5%BF%9C%3C%2FSTRONG%3E%E3%82%82%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%B4%E3%82%A1%E3%83%8F%E3%83%AA%E3%83%BBG%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarifications%20required%20for%20SBCFS2613%20Main%20state%20Faults%20reaction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81RafaR%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%A9%E3%81%AEPN%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E7%89%B9%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFMFS2613AMDA6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EFS0B%EF%BC%88FSXB%EF%BC%89%E3%82%84RSTB%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E5%8F%8D%E5%BF%9C%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%E8%87%AA%E4%BD%93%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E6%A7%8B%E6%88%90%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AEUV%2FOV%E9%9A%9C%E5%AE%B3%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E6%A7%8B%E6%88%90%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%80%8C%20%3CSPAN%20class%3D%22%22%3EFS_I_OVUV_SAFE_REACTION1%E3%80%8D%E3%81%A8%E3%80%8CFS_I_OVUV_SAFE_REACTION2%E3%80%8D%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81INTB%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%AD%E3%83%B3%E3%82%B0%2F%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%B9%E3%82%AD%E3%83%B3%E3%82%B0%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%82%92%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E9%81%8E%E9%9B%BB%E6%B5%81%E9%9A%9C%E5%AE%B3%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E5%8F%8D%E5%BF%9C%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3EOC%E9%9A%9C%E5%AE%B3%E3%81%AE%E4%BE%8B%EF%BC%88VBSTOV_I%E3%80%81VBSTOC_I%E3%80%81VPREOC_I%E3%80%81TRK1OC_I%E3%80%81COREOC_I%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B7%E3%83%B4%E3%82%A1%E3%83%8F%E3%83%AA%E3%83%BBG%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarifications%20required%20for%20SBCFS2613%20Main%20state%20Faults%20reaction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22UserName%20lia-user-name%20lia-user-rank-Contributor-I%20lia-component-message-view-widget-author-username%22%3E%3CA%20id%3D%22link_6%22%20class%3D%22lia-link-navigation%20lia-page-link%20lia-user-name-link%22%20style%3D%22color%3A%20%23333f48%3B%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248412%22%20aria-label%3D%22View%20Profile%20of%20Sivahari%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B7%E3%83%B4%E3%82%A1%E3%83%8F%E3%83%AA%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AEPN%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E7%89%B9%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%81%93%E3%82%8C%E3%81%AFFS26%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E5%BD%93%E3%81%A6%E3%81%AF%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RafaR_0-1787266460038.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RafaR_0-1787266460038.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RafaR_0-1787266460038.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395060i5880E93FF80DDCDF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RafaR_0-1787266460038.png%22%20alt%3D%22RafaR_0-1787266460038.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERafaR_0-1787266460038.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERafaR_0-1787266460038.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERafaR_0-1787266460038.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A6%81%E7%B4%84%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81M_TSD_FLG%E3%80%81M_REG_FLG%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3M_VSUP_FLG%E3%81%AE%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82FS0B(FSXB)%E3%82%84RSTB%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E5%8F%8D%E5%BF%9C%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%E8%87%AA%E4%BD%93%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%9A%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E6%A7%8B%E6%88%90%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81TSD%E9%9A%9C%E5%AE%B3%E3%81%AF%E6%98%8E%E7%A2%BA%E3%81%AA%E4%BE%8B%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E3%81%B8%E3%81%A8%E3%82%A8%E3%82%B9%E3%82%AB%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarifications%20required%20for%20SBCFS2613%20Main%20state%20Faults%20reaction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B7%E3%83%B4%E3%82%A1%E3%83%8F%E3%83%AA%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81FS26%E3%81%AB%E3%81%AF%E9%9B%BB%E6%B5%81%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8BFS_I_OVUV_SAFE_REACTION1%2F2%E3%81%AB%E7%9B%B8%E5%BD%93%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AELDO%E3%81%A8TRK%E3%81%AB%E3%81%AF%E9%9B%BB%E6%B5%81%E3%83%AA%E3%83%9F%E3%83%83%E3%82%BF%E3%83%BC%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%82%82%E5%AE%89%E5%85%A8%E3%81%AA%E7%8A%B6%E6%85%8B%E3%81%8C%E7%B6%AD%E6%8C%81%E3%81%95%E3%82%8C%E3%80%81%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E6%99%82%E9%96%93%E7%9A%84%E4%BD%99%E8%A3%95%E3%81%8C%E7%94%9F%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%99%BA%E7%94%9F%E6%BA%90%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E4%BE%8B%E3%81%88%E3%81%B0VPRE%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RafaR_0-1787355219229.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RafaR_0-1787355219229.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395132i5E00103C6334F300%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RafaR_0-1787355219229.png%22%20alt%3D%22RafaR_0-1787355219229.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERafaR_0-1787355219229.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERafaR_0-1787355219229.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
