Balancing pause on MC33774A while measuring cyclic measurements
andis_bankovics
Hi. I got a problem with MC33774A. I enable cyclic periodic measurements with balpause ( writing 3 to MC33774_ALLM_CFG_OFFSET ). It seems that this is only working when i'm balancing even cells. when balancing is enabled on odd cells then cyclic measurements shifts for those cells. sometimes less than expected sometimes more. what could be the problem?
Alternatively - how can i setup MC33774A to cyclic mode - so it sleeps, measures, sleeps?
If i try to write 2 to SYS_CYC_WAKEUP_CFG and then 10 to SYS_MODE device still goes to deep sleep instead.
RafaR
Hello andis_bankovics
Good day!
I apologize for the delay.
I can't find the register you mentioned, "MC33774_ALLM_CFG_OFFSET"? In which document did you read it?
I'll assume you were referring to ALLM_CFG
The first thing I would fix is your ALLM_CFG write value: writing 3 means MEASEN=1 and BALPAUSECYCMODEN=1, but BALPAUSELEN=0. In the register map, bits 15:2 are BALPAUSELEN, bit 1 is BALPAUSECYCMODEN, and bit 0 is MEASEN; BALPAUSELEN=0000h is explicitly NO_PAUSE. The datasheet also says the balancing pause exists to let the external filters settle before measurement. So with ALLM_CFG = 0x0003, you enabled the cyclic auto-pause feature without any actual pause time, which can absolutely leave you with shifted/offset measurements during balancing
Do you already have access to:
MC33774A data sheet rev 2.0
MC33775A and MC33774A measurement
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
RafaR
Good day!
I'm reviewing your case. I'll get back to you as soon as I have an answer.
powerset
It's been almost a week, no response from you! Our project is stuck. If you can't answer such questions, then we will be forced to switch to chips from another manufacturer!
%3CLINGO-SUB%20id%3D%22lingo-sub-2366882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBalancing%20pause%20on%20MC33774A%20while%20measuring%20cyclic%20measurements%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%20I%20got%20a%20problem%20with%26nbsp%3BMC33774A.%20I%20enable%20%3CSTRIKE%3Ecyclic%3C%2FSTRIKE%3E%26nbsp%3Bperiodic%20measurements%20with%20balpause%20(%20writing%203%20to%26nbsp%3BMC33774_ALLM_CFG_OFFSET%20).%20It%20seems%20that%20this%20is%20only%20working%20when%20i'm%20balancing%20even%20cells.%20when%20balancing%20is%20enabled%20on%20odd%20cells%20then%20cyclic%20measurements%20shifts%20for%20those%20cells.%20sometimes%20less%20than%20expected%20sometimes%20more.%20what%20could%20be%20the%20problem%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAlternatively%20-%20how%20can%20i%20setup%26nbsp%3BMC33774A%20to%20cyclic%20mode%20-%20so%20it%20sleeps%2C%20measures%2C%20sleeps%3F%3C%2FP%3E%3CP%3EIf%20i%20try%20to%20write%202%20to%26nbsp%3BSYS_CYC_WAKEUP_CFG%20and%20then%2010%20to%26nbsp%3BSYS_MODE%20device%20still%20goes%20to%20deep%20sleep%20instead.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Balancing%20pause%20on%20MC33774A%20while%20measuring%20cyclic%20measurements%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20andis_bankovics%3C%2FP%3E%0A%3CP%3EGood%20day!%3C%2FP%3E%0A%3CP%3EI'm%20reviewing%20your%20case.%20I'll%20get%20back%20to%20you%20as%20soon%20as%20I%20have%20an%20answer.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Balancing%20pause%20on%20MC33774A%20while%20measuring%20cyclic%20measurements%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt's%20been%20almost%20a%20week%2C%20no%20response%20from%20you!%20Our%20project%20is%20stuck.%20If%20you%20can't%20answer%20such%20questions%2C%20then%20we%20will%20be%20forced%20to%20switch%20to%20chips%20from%20another%20manufacturer!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Balancing%20pause%20on%20MC33774A%20while%20measuring%20cyclic%20measurements%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20andis_bankovics%3C%2FP%3E%0A%3CP%3EGood%20day!%3C%2FP%3E%0A%3CP%3EI%20apologize%20for%20the%20delay.%3C%2FP%3E%0A%3CP%3EI%20can't%20find%20the%20register%20you%20mentioned%2C%20%22MC33774_ALLM_CFG_OFFSET%22%3F%20In%20which%20document%20did%20you%20read%20it%3F%3C%2FP%3E%0A%3CP%3EI'll%20assume%20you%20were%20referring%20to%20ALLM_CFG%3C%2FP%3E%0A%3CP%3EThe%20first%20thing%20I%20would%20fix%20is%20your%20ALLM_CFG%20write%20value%3A%20writing%203%20means%20MEASEN%3D1%20and%20BALPAUSECYCMODEN%3D1%2C%20but%20BALPAUSELEN%3D0.%20In%20the%20register%20map%2C%20bits%2015%3A2%20are%20BALPAUSELEN%2C%20bit%201%20is%20BALPAUSECYCMODEN%2C%20and%20bit%200%20is%20MEASEN%3B%20BALPAUSELEN%3D0000h%20is%20explicitly%20NO_PAUSE.%20The%20datasheet%20also%20says%20the%20balancing%20pause%20exists%20to%20let%20the%20external%20filters%20settle%20before%20measurement.%20So%20with%20ALLM_CFG%20%3D%200x0003%2C%20you%20enabled%20the%20cyclic%20auto-pause%20feature%20without%20any%20actual%20pause%20time%2C%20which%20can%20absolutely%20leave%20you%20with%20shifted%2Foffset%20measurements%20during%20balancing%3C%2FP%3E%0A%3CP%3EDo%20you%20already%20have%20access%20to%3A%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsd%2Fcollateral%2F1702658797147728104124%3Fversion%3D2.0%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMC33774A%20data%20sheet%20rev%202.0%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsd%2Fcollateral%2F1678065432580728194277%3Fversion%3D2.0%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMC33775A%20and%20MC33774A%20measurement%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20information%20has%20helped%20you%2C%20please%20let%20me%20know%20if%20you%20need%20help%20with%20anything%20else.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E
