Asking for PFS2630AMDA0AD configuration
981件の閲覧回数
Andy1357
I m using FS26 to design our new project, the eval board MR-CANHUBK344 uses PFS2630AMDA0AD, but this part is not orderable part and no datasheet, so I select MFS2633AMDA3AD, but it seems a bit different from PFS2630AMDA0AD, my codes work in eval board but not for MFS2633AMDA3AD (initialization stage)......can you please provide PFS2630AMDA0AD configuration for reference? Or can you please recommend one part#, does the configuration of MFS2633AMDA0AD and PFS2630AMDA0AD are same?
963件の閲覧回数
guoweisun
Hi Andy
Please note that PFS2630AMDA0AD is blank part there is no any output if no OTP.
Please show your schematic to check which part is available for your project.
