400W HB LLC+PFC combo IC
MarkAmores
Good day!
I'm planning to start my AC-DC 375W (12V/24V) battery charger project. My current plan is to design AC-DC 400Wmax then use Buck-Boost DC-DC to accommodate the 12V and 24V mode.
May I ask for your expertise on which controller IC I can check to use on my AC-DC application?
HB LL+PFC combo IC is preferable for me as it lessens the component quantity and will be simpler to layout compare to multiple ICs.
Thank you for the suggestions!
guoweisun
HI Mark
We recommend TEA2017.
MarkAmores
Hello Guowei Sun,
Thank you for your suggestion. Can I still use this IC directly from supplier with the default values (as I checked it's a Digital configurable LLC) or do I really need to download and configure it on GUI to properly use it?
Mark
guoweisun
For this part you can use it with or without GUI configuration.
guoweisun
HI Mark
%3CLINGO-SUB%20id%3D%22lingo-sub-2297124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E400W%20HB%20LLC%2BPFC%20combo%20IC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20day!%3CBR%20%2F%3EI'm%20planning%20to%20start%20my%20AC-DC%20375W%20(12V%2F24V)%20battery%20charger%20project.%20My%20current%20plan%20is%20to%20design%20AC-DC%20400Wmax%20then%20use%20Buck-Boost%20DC-DC%20to%20accommodate%20the%2012V%20and%2024V%20mode.%3CBR%20%2F%3EMay%20I%20ask%20for%20your%20expertise%20on%20which%20controller%20IC%20I%20can%20check%20to%20use%20on%20my%20AC-DC%20application%3F%3CBR%20%2F%3EHB%20LL%2BPFC%20combo%20IC%20is%20preferable%20for%20me%20as%20it%20lessens%20the%20component%20quantity%20and%20will%20be%20simpler%20to%20layout%20compare%20to%20multiple%20ICs.%3CBR%20%2F%3EThank%20you%20for%20the%20suggestions!%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20400W%20HB%20LLC%2BPFC%20combo%20IC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20Mark%3C%2FP%3E%0A%3CP%3EWe%20recommend%20TEA2017.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20400W%20HB%20LLC%2BPFC%20combo%20IC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Guowei%20Sun%2C%3CBR%20%2F%3EThank%20you%20for%20your%20suggestion.%20Can%20I%20still%20use%20this%20IC%20directly%20from%20supplier%20with%20the%20default%20values%20(as%20I%20checked%20it's%20a%20Digital%20configurable%20LLC)%20or%20do%20I%20really%20need%20to%20download%20and%20configure%20it%20on%20GUI%20to%20properly%20use%20it%3F%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3CBR%20%2F%3EMark%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20400W%20HB%20LLC%2BPFC%20combo%20IC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20this%20part%20you%20can%20use%20it%20with%20or%20without%20GUI%20configuration.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
