what' wrong with tftp
1,758件の閲覧回数
longqiluo
hello, I am using P1023 and I designed ethernet refered to P1023RDB. now some problem happended on tftp function as below, you can see  MIB Registers: Transmit and Receive Counters , could someone tell me what/s wrong with my board?
U-Boot 2011.12 (Mar 12 2017 - 11:21:24)
CPU0:  P1023E, Version: 1.1, (0x80fe0011)
Core:  E500, Version: 5.1, (0x80212151)
Clock Configuration:
       CPU0:400  MHz, CPU1:400  MHz,
       CCB:266.667 MHz,
       DDR:400  MHz (800 MT/s data rate) (Asynchronous), LBC:16.667 MHz
       FMAN1: 266.667 MHz
L1:    D-cache 32 kB enabled
       I-cache 32 kB enabled
Board: P1023 RDS
I2C:   ready
SPI:   ready
DRAM:  256 MiB
Now running in RAM - U-Boot at: 0ff30000
Now running in function:board_early_init_r(p1023rds.c)Flash: 64 MiB
L2:    256 KB enabled
cpu_init_r() complete !
NAND:  fsl_elbc_nand: address did not match any chip selects
0 MiB
env_relocate() complete !
cpu_secondary_init_r() complete !
EEPROM: Read failed.
eth_getenv_enetaddr() complete !
getenv_IPaddr() complete !
PCIe1: Root Complex of Slot 1, no link, regs @ 0xff60a000
PCIe1: Bus 00 - 00
PCIe2: Root Complex of Slot 2, no link, regs @ 0xff609000
PCIe2: Bus 01 - 01
PCIe3: Root Complex of Slot 3, no link, regs @ 0xff60b000
PCIe3: Bus 02 - 02
pci_init() complete !
stdio_init() complete !
In:    serial
Out:   serial
Err:   serial
cosole_init_r() complete !
U-Boot relocated to 0ff30000
Net:   Fman1: Uploading microcode version 160.0.18
PHY reset timed out
FM1@DTSEC1, FM1@DTSEC2
Warning: failed to set MAC address
eth_initialize() complete !
UT_PPC PowerPC bootloader starting ...
### main_loop entered: bootdelay=3
Hit any key to stop autoboot:  0
=> md ff7e0200
ff7e0200: 00000000 00000000 00000000 00000000    ................
ff7e0210: 00000000 00000000 00000000 00000000    ................
ff7e0220: 00000000 00000000 00000000 00000000    ................
ff7e0230: 00000000 00000000 00000000 00000000    ................
ff7e0240: 00000000 00000000 00000000 00000000    ................
ff7e0250: 00000000 00000000 00000000 00000000    ................
ff7e0260: 00000000 00000000 00000000 00000000    ................
ff7e0270: 00000000 00000000 00000000 00000000    ................
ff7e0280: 00000000 00000000 00000000 00000000    ................
ff7e0290: 00000000 00000000 00000000 00000000    ................
ff7e02a0: 00000000 00000000 00000000 00000000    ................
ff7e02b0: 00000000 00000000 fe03ffff 000ffffd    ................
ff7e02c0: 00000000 00000000 00000000 00000000    ................
ff7e02d0: 00000000 00000000 00000000 00000000    ................
ff7e02e0: 00000000 00000000 00000000 00000000    ................
ff7e02f0: 00000000 00000000 00000000 00000000    ................
=> md ff7e0000
ff7e0000: 08240101 002c0000 02000700 00000000    .$...,..........
ff7e0010: 00000000 00000058 00000000 00000008    .......X........
ff7e0020: 00000000 00000000 00000000 00000000    ................
ff7e0030: 00000000 00000000 00000000 00000000    ................
ff7e0040: 00000020 00000000 00000000 00000000    ... ............
ff7e0050: 00000021 00000000 00000000 00000000    ...!............
ff7e0060: 00000000 00000000 00000000 00000000    ................
ff7e0070: 00000000 00000000 00000000 00000000    ................
ff7e0080: 00000000 00000000 00000000 00000000    ................
ff7e0090: 00000000 00000000 00000000 00000000    ................
ff7e00a0: 00000000 00000000 00000000 00000000    ................
ff7e00b0: 00000000 00000000 00000000 00000000    ................
ff7e00c0: 00000000 00000000 00000000 00000000    ................
ff7e00d0: 00000000 00000000 00000000 00000000    ................
ff7e00e0: 00000000 00000000 00000000 00000000    ................
ff7e00f0: 00000000 00000000 00000000 00000000    ................
=> md ff7e0014
ff7e0014: 00000058 00000000 00000008 00000000    ...X............
ff7e0024: 00000000 00000000 00000000 00000000    ................
ff7e0034: 00000000 00000000 00000000 00000020    ...............
ff7e0044: 00000000 00000000 00000000 00000021    ...............!
ff7e0054: 00000000 00000000 00000000 00000000    ................
ff7e0064: 00000000 00000000 00000000 00000000    ................
ff7e0074: 00000000 00000000 00000000 00000000    ................
ff7e0084: 00000000 00000000 00000000 00000000    ................
ff7e0094: 00000000 00000000 00000000 00000000    ................
ff7e00a4: 00000000 00000000 00000000 00000000    ................
ff7e00b4: 00000000 00000000 00000000 00000000    ................
ff7e00c4: 00000000 00000000 00000000 00000000    ................
ff7e00d4: 00000000 00000000 00000000 00000000    ................
ff7e00e4: 00000000 00000000 00000000 00000000    ................
ff7e00f4: 00000000 00000000 00000000 00000000    ................
ff7e0104: 00007115 40605060 00a1f037 00000800    ..q.@`P`...7....
=> mm ff7e0014
ff7e0014: 00000058 ? 1058
ff7e0018: 00000000 ? q
=> tftp test.txt
Using FM1@DTSEC1 device
TFTP from server 192.168.1.20; our IP address is 192.168.1.4
Filename 'test.txt'.
Load address: 0x1000000
Loading: T T T T T #
done
Bytes transferred = 648 (288 hex)
=> md ff7e0200
ff7e0200: 00000012 0000000d 00000000 00000000    ................
ff7e0210: 00000003 00000000 00000000 00001482    ................
ff7e0220: 000000bc 00000004 00000004 0000000a    ................
ff7e0240: 00000000 000000a8 00000000 00000000    ................
ff7e0250: 00000000 000000a5 00000000 00000000    ................
ff7e0260: 000002d6 0000000b 00000000 00000004    ................
=> tftp test.txt
Loading: T T #
done
=> md ff7e0200
ff7e0200: 00000021 0000001b 00000000 00000000    ...!............
ff7e0210: 00000004 00000000 00000000 00001fb8    ................
ff7e0220: 0000010d 00000009 00000007 00000011    ................
ff7e0230: 00000000 00000000 00000000 00000001    ................
ff7e0240: 00000000 000000e9 00000000 00000000    ................
ff7e0250: 00000000 000000e1 00000000 00000000    ................
ff7e0260: 0000052c 00000014 00000000 00000007    ...,............
=> tftp 1000000 uImage
Filename 'uImage'.
Loading: T T T T T T T T T T
Retry count exceeded; starting again
*** ERROR: `eth1addr' not set
Abort
=> md ff7e0200
ff7e0200: 00000043 0000003d 00000002 00000002    ...C...=........
ff7e0210: 00000006 00000003 00000000 00005d0a    ..............].
ff7e0220: 00000344 0000001e 0000000f 0000002e    ...D............
ff7e0230: 00000000 00000000 00000000 00000006    ................
ff7e0240: 00000000 000002f6 00000000 00000000    ................
ff7e0250: 00000000 000002da 00000000 00000000    ................
ff7e0260: 00000900 00000023 00000000 0000000a    .......#........
=> pri
baudrate=9600
bootargs=root=/dev/mtdblock2 rootfstype=jffs2 rw console=ttyS0,9600
bootcmd=bootm 0xefb70000 - 0xeda50000
bootdelay=3
bootfile=uImage
ethact=FM1@DTSEC1
ethaddr=00:04:9f:02:87:0d
fileaddr=1000000
filesize=288
fman_ucode=0xec000000
gatewayip=192.168.1.1
hwconfig=usb1:dr_mode=host,phy_type=ulpi
ipaddr=192.168.1.4
loadaddr=1000000
netmask=255.255.255.0
serverip=192.168.1.20
stderr=serial
stdin=serial
stdout=serial
Environment size: 467/8188 bytes
1,590件の閲覧回数
Pavel
NXP offers SDK 1.9 for the P1023.
This SDK is available on NXP page. Use SDKLINUX for search. Download previous version of NXP SDK.
See the Section 4.4.10.8.1 of the QorIQ-SDK-1.9-IC-RevA.pdf file.
Use the following command for uImage loading via TFTP:
=>tftp 1000000 uImage
Test your Ethernet connection using "ping 192.168.1.20" command from u-boot.
Pavel Chubakov
1,589件の閲覧回数
longqiluo
hello, I use SDK1.9 for booting, however, still the problem, I summarized the
detailed information as much as possible as attachement. please check it and
just tell me what's your viewpoint about my problem.thank you in advance!
a
body {
font-family: Helvetica, Arial, sans-serif;
-webkit-text-size-adjust: 100%;
/* Webkit */
h1, h2, h3, h4, h5, h6, p, hr {
-webkit-margin-before: 0;
-webkit-margin-after: 0;
-webkit-margin-start: 0;
-webkit-margin-end: 0;
.button td {
background-image: -moz-linear-gradient(top, #75B7E3 0%, #5498D6 50%, #408BD0
51%, #387AC8 100%) !important;
background-image: -webkit-gradient(linear, left top, left bottom, color-stop(
0%,#75B7E3), color-stop(50%,#5498D6), color-stop(51%,#408BD0), color-stop(100%,#
387AC8)) !important;
-webkit-box-shadow: inset 0 1px 0 #74b9de, 0 1px 3px rgba(0,0,0,.3) !
important;
-moz-box-shadow: inset 0 1px 0 #74b9de, 0 1px 3px rgba(0,0,0,.3) !important;
Pavel д:
NXP Community
Re: what' wrong with tftp
reply from Pavel Chubakov in QorIQ Processing Platforms - View the full
discussion
NXP offers SDK 1.9 for the P1023. This SDK is available on NXP page. Use
SDKLINUX for search. Download previous version of NXP SDK.See the Section 4.4.
10.8.1 of the QorIQ-SDK-1.9-IC-RevA.pdf file. Use the following command for
uImage loading via TFTP:=>tftp 1000000 uImage Test your Ethernet connection
Pavel Chubakov
