p2020 boot from sd card
5,913件の閲覧回数
weizhou
hi all:
My CPU is P2020,I want to boot from sd card,I use the P1020_P2020RDB_20101101_ltib software package,but no success,no message come from uart,I sure the communication between CPU and sd card is correct,the sd_clk,sd_cmd and sd_dat0 has wave from oscillograph,the flowing is my operation record:
[root@localhost u-boot-2009.11-cloud]# fdisk /dev/sdd
WARNING: DOS-compatible mode is deprecated. It's strongly recommended to
         switch off the mode (command 'c') and change display units to
         sectors (command 'u').
Command (m for help): p
Disk /dev/sdd: 16.0 GB, 16021192704 bytes
64 heads, 32 sectors/track, 15279 cylinders
Units = cylinders of 2048 * 512 = 1048576 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
   Device Boot      Start         End      Blocks   Id  System
/dev/sdd1   *           1          51       52208   83  Linux
/dev/sdd2              52       15279    15593472   83  Linux
Command action
   a   toggle a bootable flag
   b   edit bsd disklabel
   c   toggle the dos compatibility flag
   d   delete a partition
   l   list known partition types
   m   print this menu
   n   add a new partition
   o   create a new empty DOS partition table
   p   print the partition table
   q   quit without saving changes
   s   create a new empty Sun disklabel
   t   change a partition's system id
   u   change display/entry units
   v   verify the partition table
   w   write table to disk and exit
   x   extra functionality (experts only)
Command (m for help): q
[root@localhost u-boot-2009.11-cloud]# mkfs.vfat /dev/sdd1
mkfs.vfat 3.0.9 (31 Jan 2010)
[root@localhost u-boot-2009.11-cloud]# ./boot_format config_sram_p2020rdb.dat u-boot.bin -sd /dev/sdd
It is a little endian machine.
Read MBR from SDCard:
0x0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0040: 42 4f 4f 54 00 00 00 00 00 0a 1e 00 00 00 00 00
0x0050: 02 f1 0c 00 00 00 00 00 f8 f8 00 00 00 00 00 00
0x0060: f8 f8 00 00 00 00 00 00 00 00 00 06 00 00 00 00
0x0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0080: ff 72 01 00 f8 f8 00 00 ff 72 0e 44 00 00 00 0c
0x0090: ff 72 00 00 80 01 00 00 ff 72 e4 0c 00 00 00 40
0x00a0: 40 00 00 01 00 00 01 00 80 00 00 01 80 00 00 01
0x00b0: ff 70 21 0c 0f c0 88 db ff 70 21 14 24 40 10 00
0x00c0: ff 70 21 18 00 04 08 30 ff 70 21 24 08 20 01 00
0x00d0: ff 70 21 30 02 80 00 00 40 00 00 01 00 00 01 00
0x00e0: ff 70 21 28 de ad be ef ff 70 21 10 c7 0c 00 00
0x00f0: ff 70 0c 08 00 00 00 00 ff 70 0d 70 80 f0 00 1d
0x0100: ef ef ef ef 00 00 00 00 40 00 00 01 00 00 01 00
0x0110: ff 70 21 10 c7 0c 00 08 ff 70 0c 08 00 00 00 00
0x0120: ff 70 0c 10 80 f0 00 1d ef ef ef ef 00 00 00 00
0x0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01b0: 20 14 06 03 3d 00 00 00 00 00 00 00 00 00 80 01
0x01c0: 01 00 83 3f 20 32 20 00 00 00 e0 97 01 00 00 00
0x01d0: 01 33 83 3f e0 ff 00 98 01 00 00 e0 db 01 00 00
0x01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa
================== MBR ==================
boot_ind                = 0x80
start_head      = 0x1
start_cylesec   = 0x1
part_type       = 0x83
end_head                = 0x3f
end_cylsec      = 0x3220
rel_sectors     = 0x20
total_sectors   = 0x197e0
It is a valid MBR
Read DBR from SDCard:
0x0000: eb 3c 90 6d 6b 64 6f 73 66 73 00 00 02 04 04 00
0x0010: 02 00 02 00 00 f8 68 00 20 00 40 00 00 00 00 00
0x0020: e0 97 01 00 00 00 29 1a a7 c5 c5 20 20 20 20 20
0x0030: 20 20 20 20 20 20 46 41 54 31 36 20 20 20 0e 1f
0x0040: be 5b 7c ac 22 c0 74 0b 56 b4 0e bb 07 00 cd 10
0x0050: 5e eb f0 32 e4 cd 16 cd 19 eb fe 54 68 69 73 20
0x0060: 69 73 20 6e 6f 74 20 61 20 62 6f 6f 74 61 62 6c
0x0070: 65 20 64 69 73 6b 2e 20 20 50 6c 65 61 73 65 20
0x0080: 69 6e 73 65 72 74 20 61 20 62 6f 6f 74 61 62 6c
0x0090: 65 20 66 6c 6f 70 70 79 20 61 6e 64 0d 0a 70 72
0x00a0: 65 73 73 20 61 6e 79 20 6b 65 79 20 74 6f 20 74
0x00b0: 72 79 20 61 67 61 69 6e 20 2e 2e 2e 20 0d 0a 00
0x00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
================== DBR ==================
jmp_code[0]     = 0xeb
sector_size     = 0x200
root_entries    = 0x200
small_sector    = 0x0
sectors_p_fat   = 0x68
Writing image to SDCard...
OK.
Writing config words to MBR's buffer first...OK.
Writing MBR to SDCard...
boot_ind                = 0x80
start_head      = 0x1
start_cylesec   = 0x1
part_type       = 0x83
end_head                = 0x3f
end_cylsec      = 0x3220
rel_sectors     = 0x20
0x0040: 42 4f 4f 54 00 00 00 00 00 08 00 00 00 00 00 00
0x0050: 03 20 00 00 00 00 00 00 f8 f8 00 00 00 00 00 00
OK.
Writing DBR to SDCard...
jmp_code[0]     = 0xeb
sector_size     = 0x200
small_sector    = 0x0
OK.
Congratulations! It is done successfully.
the content of config_sram_p2020rdb.dat is flowing:
40:424f4f54
44:00000000
48:00010000
4c:00000000
50:00000008
54:00000000
58:f8f80000
5c:00000000
60:f8f80000
64:00000000
68:00000006
80:ff720100
84:f8f80000
88:ff720e44
8c:0000000c
90:ff720000
94:80010000
98:ff72e40c
9c:00000040
a0:40000001
a4:00000100
a8:80000001
ac:80000001
has  where improper operation?
It torments me two weeks!!!!
thank you!
thank you!
13 返答(返信)
5,344件の閲覧回数
ufedor
In the log it is printed "part_type = 0x83" - this is incorrect.
Should be "part_type = 0x6" - because only FAT16 and FAT32 are supported.
Use 'fdisk' to to change the partition ID = 6
5,344件の閲覧回数
weizhou
Thank you ,ufedor
My sdk is  P1020_P2020RDB_20101101_ltib.
there is no any debugger connect to my board.
the board designed by I in scratch,not offical develop board.
I change part_type=6 use 'fdisk' ,but still no success,but I add address/value pairs in config_sram_p1022ds.dat that operates GPIO port 9 that connect a LED on my board,the LED can been turned on,but I can not  turn off it in start.S.
the flowing is whole information:
[root@localhost u-boot-2009.11-cloud]# ./boot_format config_sram_p1022ds.dat u-boot.bin -sd /dev/sde
0x0050: 06 20 20 00 00 00 00 00 f8 f8 00 00 00 00 00 00
0x0060: f8 ff f0 00 00 00 00 00 00 00 00 06 00 00 00 00
0x00b0: 40 00 00 01 00 00 01 00 80 00 00 01 80 00 00 01
0x00c0: 40 00 00 01 00 00 01 00 80 00 00 01 80 00 00 01
0x00d0: 40 00 00 01 00 00 01 00 80 00 00 01 80 00 00 01
0x0100: ef ef ef ef ff ff 00 00 ff e0 f0 08 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 01
0x01c0: 01 00 06 c0 34 14 34 00 00 00 10 37 03 00 00 00
0x01d0: 01 15 83 c0 74 7d 44 37 03 00 54 48 37 00 00 00
boot_ind                = 0x80
start_head      = 0x1
start_cylesec   = 0x1
part_type       = 0x6
end_head                = 0xc0
end_cylsec      = 0x1434
rel_sectors     = 0x34
total_sectors   = 0x33710
It is a valid MBR
0x0010: 02 00 02 00 00 f8 d0 00 34 00 c1 00 00 00 00 00
0x0020: 10 37 03 00 00 00 29 4d fb ee 26 20 20 20 20 20
jmp_code[0]     = 0xeb
sector_size     = 0x200
small_sector    = 0x0
sectors_p_fat   = 0xd0
OK.
boot_ind                = 0x80
start_head      = 0x1
start_cylesec   = 0x1
part_type       = 0x6
end_head                = 0xc0
end_cylsec      = 0x1434
rel_sectors     = 0x34
0x0060: f8 ff f0 00 00 00 00 00 00 00 00 08 00 00 00 00
0x00a0: ff 70 f0 00 00 40 00 00 ff 70 f0 08 00 40 00 00
OK.
jmp_code[0]     = 0xeb
sector_size     = 0x200
small_sector    = 0x0
OK.
the content of config_sram_p1022ds.dat is flowing:
040:424f4f54
044:00000000
048:00010000
04c:00000000
050:00001000
054:00000000
058:f8f80000
05c:00000000
060:f8fff000
064:00000000
068:00000008
080:ff720100
084:f8f80000
088:ff720e44
08c:0000000c
090:ff720000
094:80010000
098:ff72e40c
09c:00000040
0a0:ff70f000
0a4:00400000
0a8:ff70f008
0ac:00400000
0b0:40000001
0b4:00000100
0b8:80000001
0bc:80000001
5,344件の閲覧回数
weizhou
I do not know that my u-boot whether has been executed,the code I added to control GPIO in start.S  is the first instruction,flowing is :
.globl _start_e500
_start_e500:
/*let the status led turn off*/
lisr1,GPIOBASE@h //0xff70f000
lisr0,GPIOVAL@h  //0x00000000
stwr0,0(r1)
stwr0,+8(r1)
/* clear registers/arrays not reset by hardware */
/* L1 */
lir0,2
mtsprL1CSR0,r0/* invalidate d-cache */
mtsprL1CSR1,r0/* invalidate i-cache */
mfsprr1,DBSR
mtsprDBSR,r1/* Clear all valid bits */
so,I feel the u-boot is not executed at all.
5,344件の閲覧回数
ufedor
Please consider to open a sevice case because this could be a complicated technical issue - refer to the How I could create a Service Request?
Please provide the SDCARD U-Boot binary image for inspection.
5,344件の閲覧回数
weizhou
I do not know how provide my u-boot binary file ? !
5,344件の閲覧回数
ufedor
5,344件の閲覧回数
weizhou
I have created a service request. thank you.
5,344件の閲覧回数
weizhou
hi ufedor:
this is my u-boot.bin binary file. I use flowing way to compile it:
make P2020RDB_SDCARD_config
make
5,344件の閲覧回数
ufedor
Please use attached pre-built SDCARD U-Boot image from the SDK 1.4.
If there will be no UART output, then the board has to be debugged.
5,344件の閲覧回数
weizhou
hi ufedor:
I use pre-build sdcard u-boot image from the sdk 1.4,but no message come from uart,the flowing is my operation recorder:
./boot_format config_sram_p1022ds.dat u-boot-sd-P2020RDB-PC_SDCARD-git-r34.bin -sd /dev/sde
boot_ind = 0x80
start_head = 0x1
start_cylesec = 0x1
part_type = 0x6
end_head = 0xc0
end_cylsec = 0x1434
rel_sectors = 0x34
It is a valid MBR
jmp_code[0] = 0xeb
sector_size = 0x200
small_sector = 0x0
OK.
boot_ind = 0x80
start_head = 0x1
start_cylesec = 0x1
part_type = 0x6
end_head = 0xc0
end_cylsec = 0x1434
rel_sectors = 0x34
OK.
jmp_code[0] = 0xeb
sector_size = 0x200
small_sector = 0x0
OK.
5,344件の閲覧回数
weizhou
OK,thank you ufedor,I try it.
5,344件の閲覧回数
ufedor
1) Which Freescale's SDK is used?
2) Please provide the SDCARD U-Boot binary image for inspection.
3) Is debugger connection possibe during booting from SD card?
4) Is the board capable to boot from another source (NOR, NAND, SPI)?
5,344件の閲覧回数
weizhou
My board only can boot from sd
