how to find the linux driver source code for nandFlash?
ソリューションへジャンプ
3,419件の閲覧回数
yinux
I want to find the nandflash driver in the linux sdk .
1)   download Virtual Host Enviroment: QorIQ DPAA SDK v1.9 PPCE500MC with Virtual Host Enviroment
2) cd /SDK/QorIQ-SDK-V1.9-20151210-yocto/build_p2041rdb/tmp/work-shared/p2041rdb/kernel-source/drivers/mtd/nand
    which c source will fit the nandFlash MT29F2G08AAD?
thanks for your help.
2,898件の閲覧回数
yipingwang
Hello yang yang,
Please refer to the file in drivers/mtd/nand/fsl_elbc_nand.c for P2041RDB.
Yiping
4 返答(返信)
2,898件の閲覧回数
yipingwang
Hello yang yang,
If your want to use IFC controller, please consider about T series processors.
Please refer to drivers/mtd/nand/fsl_ifc_nand.c for IFC Flash Controller NAND Machine driver.
Yiping
2,898件の閲覧回数
yinux
thanks for your reply.
now I cannot  change my ppc p2041 to the T serial.
I want to know the linux drivers , how to use the ecc alg,  in the p2041RDB.
which c source will fit the nandFlash MT29F2G08AAD (supported in the 2041RDB board)?
2,899件の閲覧回数
yipingwang
Hello yang yang,
Yiping
2,898件の閲覧回数
yinux
got ,thanks very much.
