P4080DS Disable Chip Select and Memory Controller Interleaving
2,126件の閲覧回数
yyurtcan
I have p4080ds board. In u-boot, both chip select and memory controller (cache line) interleaving are enabled.
First, I want to disable chip select interleaving and enable memory controller, boot board.
Second I want to disable memory controller interleaving and enable chip select interleaving, boot board.
Finally I want to diasble both.
How can I do that? Which registers do I need to change?
Best regards.
1,685件の閲覧回数
Bulat
DDR interleaving can be configured in include\configs\coherent_ds.h file. Relevant lines by default:
     "hwconfig=fsl_ddr:ctlr_intlv=cacheline,"
     "bank_intlv=cs0_cs1;"
To disable memory controller interleaving you need to set
     "hwconfig=fsl_ddr:ctlr_intlv=null,"
To disable chip select  interleaving you need to set
     "bank_intlv=null;"
More details can be found in doc\README.fsl-ddr file.
Bulat
