hi,
I am using P2041RDB-PB board with SDK1.3
I am using reflector application, able to receive packets modify them and send using "ppac_send_frame(tx_fqid, fd)", working fine.
I am using tun/tap what ever the packets i am receiving from outside I am able to send to tun/tap (i am getting replay from linux through tun/tap) but what ever the packets receiving from tun/tap unable to send to port.
my question is,
how to send a packet out which is generated in program?
Thanks & Regards
Shashank
Helpful application note about this: http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN4479.pdf?fsrch=1&sr=1
hi
not able to get AN4479.pdf, the above link is not working
can you tell where can we get AN4479.pdf?
Sharath
