P1022: Booting from NOR Flash
1,209 次查看
senthil_k
We are using P1022 processor based custom board which has both SDcard and NOR Flash boot options.
Currently we are able to successfully boot from SDCard and next we need to try booting from Parallel NOR Flash (S29GL01GP11TFIR10).
Can you please let us know which offset in Flash we need to program our UBoot/Linux/dtb images and please let us know the procedure for booting from Parallel NOR Flash.
Note: We doesn't have EEPROM in our custom board.
1,007 次查看
alexander_yakov
In case if you are using our "Linux SDK for for QorIQ Processors" to build your "UBoot/Linux/dtb images", than please refer to Chapter 4 "Deployment Guides" of the document named "QorIQ SDK Documentation", supplied with Linux SDK (document code "QorIQSDK")
Alexander
