P1010RDB. DDR ECC enable procedure
1,330 次查看
alessandronasor
Hello. I'm working with P1010RDB. Looking the boot I've seen DDR ECC is OFF.
I've done some performance tests with this feature OFF
I would like to enable it to evaluate how this impact on performance.
i haven't code warrior. Should you please indicate me:
  1. A proper DDR ECC enable procedure.
  2. If you have some benchmark data that shows on P1010RDB how the DDR ECC impact on performance.
Alessandro
0 回复数
