How to configure the P1010 RDB binaries by using the Yocto SDK 1.4?
748件の閲覧回数
haowang
Hi, I'm using the Freescale SDK 1.4 to build the kernel of the P1010 RDB. If I use 'bitbake fsl-image-minimal', some u-boot and kernel images will be build.
Now I don't want the Security Engine 4.4 to be activated in the boot, how can I configure this before the kernel is complied?
Thanks for the help.
451件の閲覧回数
yipingwang
About how to configure and rebuild Linux Kernel, please try to use the following steps.
1. $ bitbake -c patch virtual/kernel -f
2. Do menuconfig
$ bitbake -c menuconfig virtual/kernel
The following is CAAM configuration options, please disable them.
<*> Freescale CAAM-Multicore driver backend
(9) Job Ring size
[ ] Job Ring interrupt coalescing
<*> Register algorithm implementations with the Crypto API
<*> Register hash algorithm implementations with Crypto API
<*> Register caam device for hwrng API
save the configuration and rebuild Kernel.
$ bitbake -c compile -f virtual/kernel
$ bitbake virtual/kernel
