Hi, as the title said. I would like to know more details about the NAND flash that P1010rdb is using(e.g. how many blocks, how many bytes for the row and column addressing, etc.). If I can now the type and brand of the nand flash.
Thanks.
NAND flash used on P1010RBD is Samsung K9F5608U0D-PCB0
NAND flash used on P1010RDB-PB is Micron MT29F16G08ABABAWP:B
Thanks for your reply. Is there any documentation (like the P1010 RDB User Guide) exist?
Since I would like to know more details about what are exactly containing in the board. Could you help me?
Thanks.
P1010RDB board documentation and schematic files are available only with board, on USB stick supplied in board package.
Thanks again. For the Nor flash, on the fact sheet , it says it's 32M. Could you tell me the type of the NOR flash?
You simply can use CodeWarrior for finding all flashes supported by a board. The FlashProgrammer tasks will show you the device names.
For your requested device - S29GL256S90TFI01 (in CW you're showing a compatible device - S29GL256P).
Marius
