Decrementer interrupt in linux project
1,733 次查看
pabloramos
Hi everyone,
I would like to know if it is possible to have decrementer interrupt in a Multicore Linux Project.
I have tried to use the interrupt like a bareboard Project  and it compiles but at the debug time it remains blocked.
Does anyone have  perform interrupts in Linux multicore projects? How to do that?
Thanks in advanced.
标签 (1)
2 回复数
1,518 次查看
bpe
If the question is specifically about Linux, the kernel does use Decrementer.
It registers Decrementer as a standard clock event device. Related code can be found in
arch/powerpc/kernel/time.c, arch/powerpc/kernel/head_fsl_booke.S and
arch/powerpc/kernel/head_booke.h.
More information on clock event device and related concepts can be found in
Documentation/timers/highres.txt
1,518 次查看
lunminliang
What do you mean by "at the debug time it remains blocked"? Did you find "TSR[DIS]" setted but PC not jumppting into handler?
