11AC module bcm43460
kevincheng
We designed a 11ac access point base on P1020WLAN EVB , and WiFi module is bcm43460.
But we found there've no driver on Qor SDK or LTIB SDK for this module. So, have any one known how to get this driver and application ?    Thanks!!
Kevin
alexander_yakov
I'm quite sure this driver should be available as a part of P1020EWLAN software, at least this is explicitly mentioned in this document:
http://www.freescale.com/files/training/doc/dwf/DWF13_APF_NET_T0580.pdf
Alexander
