Enabling SD Interface on P1025 Reference Design Board
To enable SD interface in SPI boot on P1025RDB: 1. Perform the following updates in u-boot a) Modify pmuxcr to enable SD bus in case of SPI boot b) Update the corresponding static mux implementation in u-boot 2. Perform the following updates in Linux a) Disable IFC from device tree and kernel defconfig
The patch details to enable SD interface are given below. A zip file, AN4336SW.zip, containing the patches for u-boot and Linux accompanies this application note. The file can be downloaded from [1].
U-Boot
  •   Extract the u-boot code from the QorIQ SDK 1.0.1 iso
  •   Apply the patch, u-boot-p1025rdb-enabling-sd-in-spi-boot.patch
  •   Compile the u-boot using "make" command for SPI Flash
   make ARCH=powerpc   CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/bin/powerpc-linux-gnu- p1025RDB_SPIFLASH
  •   Use the boot_format utility to generate the spiimage. For more information, see SDK manual.
  •   Update the SPI Flash with the above built spiimage
Linux
  • Extract the Linux source code from QorIQ SDK 1.0.1 iso
  • Apply the patch, linux-p1025rdb-enabling-sd-in-spi-boot.patch
  • Compile Linux using make command
 #make ARCH=powerpc  CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/bin/powerpc-linux-gnuarch/  powerpc/configs/qoriq_sdk_nonsmp_defconfig  #make ARCH=powerpc  CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/bin/powerpc-linux-gnu-
  • Compile the dts
 ./sripts/dtc/dtc -f -I dts -O dtb -R 8 -S 0x3000  arc/powerpc/boot/dts/p1025rdb.dts.dts > p1025rdb.dtb.dtb
  • With the updated SPI bootloader, Linux uImage and p1025rdb.dtb, the user must be able to enable SD interface on p1025RDB.
NOTE
  • The above-mentioned changes must be done only when the user specifically requires the SD interface using SPI boot.
  • For all other boot methods, these patches must not be used.
%3CLINGO-SUB%20id%3D%22lingo-sub-1103718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EP1025%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AESD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EP1025RDB%20%E3%81%AE%20SPI%20%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%20SD%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3A%201.%20u-boot%20%E3%81%A7%E6%AC%A1%E3%81%AE%E6%9B%B4%E6%96%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%20a)%20SPI%20%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%20pm%20uxcr%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%20SD%20%E3%83%90%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%20b)%20u-boot%202%20%E3%81%AE%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E9%9D%99%E7%9A%84%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Linux%E3%81%A7%E6%AC%A1%E3%81%AE%E6%9B%B4%E6%96%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99a)%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABdefconfig%E3%81%8B%E3%82%89IFC%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ESD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82zip%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20AN4336SW.zipu-boot%20%E3%81%A8%20Linux%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CA%20class%3D%22external%20autonumber%22%20href%3D%22http%3A%2F%2Fwww.freescale.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22external%20autonumber%22%3E1%3C%2FSPAN%3E%3C%2FA%3E%3CA%20class%3D%22external%20autonumber%22%20href%3D%22http%3A%2F%2Fwww.freescale.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5D%3C%2FA%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1081645692%22%20id%3D%22toc-hId-1081645692%22%20id%3D%22toc-hId-2005251377%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EU-Boot%20%3C%2FSPAN%3E%3C%2FH3%3E%3CUL%3E%3CLI%3EQorIQ%20SDK%201.0.1%20iso%E3%81%8B%E3%82%89u-boot%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%91%E3%83%83%E3%83%81%20u-boot-p1025rdb-enabling-sd-in-spi-boot.patch%20%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3ESPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%20%22make%22%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20u-boot%20%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20translate%3D%22no%22%3E%26nbsp%3B%26nbsp%3B%20make%20ARCH%3Dpowerpc%20%26nbsp%3B%20CROSS_COMPILE%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.5.55-eglibc-2.11.55%2Fpowerpc-linux-gnu%2Fbin%2Fpowerpc-linux-gnu-%20p1025RDB_SPIFLASH%3C%2FPRE%3E%3CUL%3E%3CLI%3Eboot_format%20%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%83%94%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81SDK%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20spiimage%20%E3%81%A7%20SPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--725808771%22%20id%3D%22toc-hId--725808771%22%20id%3D%22toc-hId-197796914%22%3E%3CSPAN%20class%3D%22mw-headline%22%3ELinux%20%3C%2FSPAN%3E%3C%2FH3%3E%3CUL%3E%3CLI%3EQorIQ%20SDK%201.0.1%20iso%E3%81%8B%E3%82%89%E3%81%AELinux%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%8A%BD%E5%87%BA%3C%2FLI%3E%3CLI%3E%E3%83%91%E3%83%83%E3%83%81%20linux-p1025rdb-enabling-sd-in-spi-boot.patch%20%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3Emake%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Linux%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20translate%3D%22no%22%3E%20%23make%20ARCH%3Dpowerpc%26nbsp%3B%20CROSS_COMPILE%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.5.55-eglibc-2.11.55%2Fpowerpc-linux-gnu%2Fbin%2Fpowerpc-linux-gnuarch%2F%26nbsp%3B%20powerpc%2Fconfigs%2Fqoriq_sdk_nonsmp_defconfig%26nbsp%3B%20%23make%20ARCH%3Dpowerpc%26nbsp%3B%20CROSS_COMPILE%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.5.55-eglibc-2.11.55%2Fpowerpc-linux-gnu%2Fbin%2Fpowerpc-linux-gnu-%3C%2FPRE%3E%3CUL%3E%3CLI%3Edts%20%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20translate%3D%22no%22%3E%20.%2Fsripts%2Fdtc%2Fdtc%20-f%20-I%20dts%20-O%20dtb%20-R%208%20-S%200x3000%26nbsp%3B%20arc%2Fpowerpc%2Fboot%2Fdts%2Fp1025rdb.dts.dts%20%26gt%3B%20p1025rdb.dtb.dtb%3C%2FPRE%3E%3CUL%3E%3CLI%3E%20%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9FSPI%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81Linux%20uImage%E3%80%81p1025rdb.dtb%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E3%80%81p1025RDB%E3%81%A7SD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FLI%3E%3C%2FUL%3E%3CH4%20id%3D%22toc-hId--35247297%22%20id%3D%22toc-hId--35247297%22%20id%3D%22toc-hId-888358388%22%3E%3CSPAN%20class%3D%22editsection%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CH4%20id%3D%22toc-hId--1842701760%22%20id%3D%22toc-hId--1842701760%22%20id%3D%22toc-hId--919096075%22%3E%3CSPAN%20class%3D%22editsection%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mw-headline%22%3E%20%E6%89%8B%E8%A8%98%20%3C%2FSPAN%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%20%E4%B8%8A%E8%A8%98%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%20SPI%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20SD%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E7%89%B9%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FLI%3E%3CLI%3E%20%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20P1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 01:49 AM
更新者:
