xaf_record Example Fails with comp_setup failure in SDK_26_06_00_MIMXRT700-EVK
436件の閲覧回数
suhas1503
  • Board: MIMXRT700-EVK
  • SDK Version: SDK_26_06_00_MIMXRT700-EVK
  • Example: SDK_26_06_00_MIMXRT700-EVK/mcuxsdk/middleware/cadence/multicore-xaf/examples/xaf_record/cm/
  • Build Configuration: Default example without modifications
After starting DMIC recording using the shell command: record_dmic en
The DSP reports a component setup failure, preventing the recording pipeline from functioning correctly.
console output
DSP audio framework demo start
[CM33 Main] Configure codec
[DSP_Main] Cadence Xtensa Audio Framework
[DSP_Main] Library Name: Audio Framework (Hostless)
[DSP_Main] Library Version: 3.6
[DSP_Main] API Version: 3.4
[DSP_Main] start
[DSP_Main] established RPMsg link
[CM33 Main] DSP image copied to DSP TCM
[CM33 Main][APP_DSP_IPC_Task] start
[CM33 Main][APP_Shell_Task] start
Copyright 2024 NXP
>> record_dmic en
[CM33 CMD] Setting VIT language to en
[DSP_Main] Number of channels 1, sampling rate 16000, PCM width 32
[CM33 CMD] [APP_DSP_IPC_ Task] response from DSP, cmd: 13, error: 0
[DSP Record] Audio Device Ready
[CM33 CMD] DSP DMIC Recording started
[DSP Record] comp_setup failure: 4294967294
[CM33 CMD] To see VIT functionality say wakeword and command
[CM33 CMD] [APP_DSP_IPC_ Task] response from DSP, cmd: 13, error: 4294967295
Expected Behavior
After executing:
record_dmic en
The DMIC recording pipeline should initialise successfully, allowing audio capture and VIT wake-word detection without any component setup errors.
Actual Behavior
The DSP reports:
followed by an IPC response with:
error: 4294967295
As a result, the recording pipeline does not function as expected.
Request
Could you please help identify the following?
  1. What causes the comp_setup failure, 4294967294, in the default xaf_record example?
  2. Does this indicate a missing DSP component, codec configuration issue, or another initialisation problem?
  3. Is there any known issue or patch for the xaf_record example in SDK 26.06.00?
  4. Are any additional configuration steps required before using the record_dmic command?
Any guidance on debugging this issue would be appreciated.
4 返答(返信)
375件の閲覧回数
suhas1503
We have downloaded the sdk from the below link; also attaching the snap; we downloaded sdk version 26.06.00Screenshot from 2026-08-03 12-23-01.png
https://mcuxpresso.nxp.com/download/c7b3a37a7e9e773a92291031541e9b58
we are compiling and flashing through command line
Build command:
west build -b mimxrt700evk middleware/cadence/multicore-xaf/examples/xaf_record/cm -d build/ -- -Dcore_id=cm33_core0 -Dtarget=flash_debug
Flash command:
LinkServer flash MIMXRT798S:MIMXRT700-EVK load dsp_xaf_record_cm33_core0.elf
367件の閲覧回数
Gavin_Jia
I was able to reproduce the issue using the same package.
I’ll conduct an internal investigation to see if there are any discrepancies. This may take some time. In the meantime, I recommend that you continue development based on the MCUXpresso IDE project to save the time.
Once the issues with the SDK package based on the ARM GCC toolchain have been resolved, you can port your project over.
379件の閲覧回数
Gavin_Jia
Hi @suhas1503 ,
Could you please provide some information about the IDE you're using? Is it MCUXpresso IDE or VS Code?
I tried to reproduce the issue in MCUXpresso IDE, but it ran fine.
I didn't find anything related to “[DSP VIT]” in your log information. I suspect this might be due to missing content in your local project rather than a software bug.
Gavin
370件の閲覧回数
suhas1503
Please find the above reply.
%3CLINGO-SUB%20id%3D%22lingo-sub-2400875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESDK_26_06_00_MIMXRT700-EVK%20%E3%81%A7%E3%80%81xaf_record%20%E3%81%AE%E4%BE%8B%E3%81%8C%20comp_setup%20%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%AB%E3%82%88%E3%82%8A%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%3EMIMXRT700-EVK%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3ESDK%20Version%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%20SDK_26_06_00_MIMXRT700-EVK%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%3E%E4%BE%8B%3A%26nbsp%3BSDK_26_06_00_MIMXRT700-EVK%2Fmcuxsdk%2Fmiddleware%2Fcadence%2Fmulticore-xaf%2Fexamples%2Fxaf_record%2Fcm%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E4%BE%8B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20record_dmic%20en%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DMIC%20%E9%8C%B2%E9%9F%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%9F%E5%BE%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EDSP%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%A4%B1%E6%95%97%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%80%81%E8%A8%98%E9%8C%B2%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E******************************%3CBR%20%2F%3EDSP%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%83%87%E3%83%A2%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E******************************%3C%2FP%3E%3CP%3E%5BCM33%20%E3%83%A1%E3%82%A4%E3%83%B3%5D%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5BDSP_Main%5DCadence%20Xtensa%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%3CBR%20%2F%3E%5BDSP_Main%5D%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E5%90%8D%3AAudio%20Framework(%E3%83%9B%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9)%3CBR%20%2F%3E%5BDSP_Main%5D%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A3.6%3CBR%20%2F%3E%5BDSP_Main%5DAPI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A3.4%3C%2FP%3E%3CP%3E%5BDSP_Main%5D%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5BDSP_Main%5D%20RPMsg%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5BCM33%E3%83%A1%E3%82%A4%E3%83%B3%5DDSP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92DSP%20TCM%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%3CBR%20%2F%3E%5BCM33%E3%83%A1%E3%82%A4%E3%83%B3%5D%5BAPP_DSP_IPC_Task%5D%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5BCM33%E3%83%A1%E3%82%A4%E3%83%B3%5D%5BAPP_Shell_Task%5D%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%E8%91%97%E4%BD%9C%E6%A8%A9%202024%20NXP%3C%2FP%3E%3CP%3E%26gt%3B%26gt%3B%20record_dmic%20en%3CBR%20%2F%3E%5BCM33%20CMD%5DVIT%20%E8%A8%80%E8%AA%9E%E3%82%92%20en%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5BDSP_Main%5D%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E6%95%B01%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%8816000%E3%80%81PCM%E5%B9%8532%3CBR%20%2F%3E%5BCM33%20CMD%5D%5BAPP_DSP_IPC_%E3%82%BF%E3%82%B9%E3%82%AF%5DDSP%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%80%81cmd%3A%2013%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3A%200%3CBR%20%2F%3E%5BDSP%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%5D%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5BCM33%20CMD%5DDSP%20DMIC%E9%8C%B2%E9%9F%B3%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E%5BDSP%E8%A8%98%E9%8C%B2%5D%20comp_setup%E6%95%85%E9%9A%9C%3A4294967294%3CBR%20%2F%3E%5BCM33%20CMD%5DVIT%E6%A9%9F%E8%83%BD%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%AB%E3%81%AFwakeword%E3%81%A8command%E3%82%92%E9%81%B8%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%5BCM33%20CMD%5D%5BAPP_DSP_IPC_%E3%82%BF%E3%82%B9%E3%82%AF%5DDSP%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%80%81cmd%3A%2013%E3%80%81error%3A%204294967295%3CBR%20%2F%3E%5BCM33%20CMD%5DDSP%20DMIC%E9%8C%B2%E9%9F%B3%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E%5BCM33%20CMD%5DVIT%E6%A9%9F%E8%83%BD%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%AB%E3%81%AFwakeword%E3%81%A8command%E3%82%92%E9%81%B8%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8B%E5%8B%95%E4%BD%9C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E8%A1%8C%E5%BE%8C%EF%BC%9A%3C%2FP%3E%3CP%3Erecord_dmic%20en%3C%2FP%3E%3CP%3EDMIC%E9%8C%B2%E9%9F%B3%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%80%81%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E8%A8%AD%E5%AE%9A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%81%AB%E9%9F%B3%E5%A3%B0%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%84VIT%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%83%AF%E3%83%BC%E3%83%89%E6%A4%9C%E5%87%BA%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%AE%9F%E9%9A%9B%E3%81%AE%E8%A1%8C%E5%8B%95%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EDSP%E3%81%AE%E5%A0%B1%E5%91%8A%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5BDSP%E8%A8%98%E9%8C%B2%5D%20comp_setup%E6%95%85%E9%9A%9C%3A4294967294%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%B6%9A%E3%81%84%E3%81%A6%E3%80%81IPC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%204294967295%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A6%81%E6%9C%9B%3CBR%20%2F%3E%3C%2FSTRONG%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3COL%3E%3CLI%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AExaf_record%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%80%81comp_setup%E3%82%A8%E3%83%A9%E3%83%BC4294967294%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%82%8C%E3%81%AFDSP%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E6%AC%A0%E8%90%BD%E3%80%81%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E4%BB%96%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FLI%3E%3CLI%3ESDK%2026.06.00%E3%81%AExaf_record%E4%BE%8B%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%84%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3Erecord_dmic%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%89%8B%E9%A0%86%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2400875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20xaf_record%20Example%20Fails%20with%20comp_setup%20failure%20in%20SDK_26_06_00_MIMXRT700-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20xaf_record%20Example%20Fails%20with%20comp_setup%20failure%20in%20SDK_26_06_00_MIMXRT700-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%90%8C%E3%81%98%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%86%85%E9%83%A8%E8%AA%BF%E6%9F%BB%E3%82%92%E5%AE%9F%E6%96%BD%E3%81%97%E3%80%81%E7%9F%9B%E7%9B%BE%E7%82%B9%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E9%96%93%E3%80%81%E6%99%82%E9%96%93%E3%82%92%E7%AF%80%E7%B4%84%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABMCUXpresso%20IDE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E9%96%8B%E7%99%BA%E3%82%92%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EARM%20GCC%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FSDK%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20xaf_record%20Example%20Fails%20with%20comp_setup%20failure%20in%20SDK_26_06_00_MIMXRT700-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263204%22%20target%3D%22_blank%22%3E%40suhas1503%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8BIDE%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E6%83%85%E5%A0%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FMCUXpresso%20IDE%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82VS%20Code%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EMCUXpresso%20IDE%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gavin_Jia_0-1785739563410.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gavin_Jia_0-1785739563410.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gavin_Jia_0-1785739563410.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393614i8A5F4DD05285371B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Gavin_Jia_0-1785739563410.png%22%20alt%3D%22Gavin_Jia_0-1785739563410.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E6%83%85%E5%A0%B1%E3%81%AB%E3%81%AF%E3%80%8C%5BDSP%20VIT%5D%E3%80%8D%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%82%B0%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%82%8A%E3%81%AF%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%AE%E3%83%A3%E3%83%93%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20xaf_record%20Example%20Fails%20with%20comp_setup%20failure%20in%20SDK_26_06_00_MIMXRT700-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89SDKs%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%B9%E3%83%8A%E3%83%83%E3%83%97%E3%81%AE%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%82%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SDKs%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B326.06.00%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202026-08-03%2012-23-01.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-08-03%2012-23-01.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393618i531A7EA8AE9BF034%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-08-03%2012-23-01.png%22%20alt%3D%22Screenshot%20from%202026-08-03%2012-23-01.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fdownload%2Fc7b3a37a7e9e773a92291031541e9b58%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%2Fdownload%2Fc7b3a37a7e9e773a92291031541e9b58%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%0A%0A%5B%5B%20%23%23%20completed%20%23%23%5D%5D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20west%20build%20-b%20mimxrt700evk%20middleware%2Fcadence%2Fmulticore-xaf%2Fexamples%2Fxaf_record%2Fcm%20-d%20build%2F%20--%20-Dcore_id%3Dcm33_core0%20-Dtarget%3Dflash_debug%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20LinkServer%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20MIMXRT798S%3AMIMXRT700-EVK%20%E3%83%AD%E3%83%BC%E3%83%89%20dsp_xaf_record_cm33_core0.elf%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
