pcf8563 Current Drain
ソリューションへジャンプ
2,706件の閲覧回数
fav
I'm using the PCF8563T to interrupt a cpu every 24 hrs. Vdd is 3.3v and I'm using a 32.768 kHz external crystal which is sufficiently accurate for my app with no compensation. The configuration works as expected with no problems. The issue I have is that with no I2C or interrupt activity and no clock outputs, the chip is drawing about 1.6ma while internally maintaining the time. Is this normal or am I overlooking something in the configuration setup to achieve lower current drain?
Thanks for any assistance with this.
Frank
2,503件の閲覧回数
guoweisun
This's  impossible, how many boards did you test? same result?
4 返答(返信)
2,504件の閲覧回数
guoweisun
2,480件の閲覧回数
fav
I was unable to try another meter over the weekend, but today I used a different meter and the current draw was about 300nA. Sorry for the oversight and thank you for responding.
Frank
2,700件の閲覧回数
guoweisun
Can you share with your schematic?
2,643件の閲覧回数
fav
Thanks for responding.
I misstated the current draw in my original post. 1.6 ma is the current draw from a 12v to 3.3v dc-dc converter. The current draw, as noted in the schematic, is 5.1 ma. I have tried configurations with no interrupt and with I2C connections removed after configuring the RTC, but the high current drain remains.
