marking codes
marking codes
5,564 次查看
frank_salvia
What is the correct marking code on a BFT92? The data sheet says W1% and the part is marked W1W. Do I have the correct part?
5,173 次查看
andrei_skok
According to the BFT92 datasheet  marking is W1%.
The wildcard % is replaced with a letter representing the assembly site.
In your case W1W means BFT92 made in China.
5,173 次查看
frank_salvia
Thank You!
