landscape gui-guider view at launch widget examples
2,576 次查看
nicomarconi
Hi, i am working with MIMXRT1170 EVKB and the RK055HDMIPI4MA0 display.
My OS is Ubuntu 22.04
I am starting working with gui-guider and, i wanted to learn to design any display human interface for my future projects.
So when i launch gui-guider and want to see in landscape view any widget, for example, ProgressBar, the only way to do it is selecting 800x480 (width x height), but when debug the project to the board it goes totally blank.
I am sure is a setting problem, but i don't know haw to change it.
My question are:
1) Haw can i see the view of gui-guider in landscape mode at the moment of launching a project example with my board and display.
Thanks a lot for your help
4 回复数
2,461 次查看
Gavin_Jia
Hi @nicomarconi ,
Thanks for your interest in NXP MIMXRT series!
From your screenshot, it seems that the incorrect LCD is selected. Suggest you try creating the project this way:
Gavin
2,459 次查看
nicomarconi
Thanks a lot for your answer. My question is , is there a way to lunch gui-guider in landscape mode. Because all examples in gui-guider are launched in portrait mode. If it is not possible, can you help me to rotate to landscape mode any widget example once it is deployed to the board? Thanks a lot for your help
2,452 次查看
Gavin_Jia
Hi @nicomarconi ,
As you can see, by configuring the width and height of the LCD like this in my screenshot, it is landscape.
2,445 次查看
nicomarconi
EXCELLENT.....THANKS A LOT...I didn't know that it is possible to edit the name of the Display in the "Display Panel Type".....thanks thanks thanks thanks
