kernel panic with booting eMMC on imx8navq
2,320 次查看
mmt45
Hello, I was following this guide to setup cognipilot on NavQPlus (imx8navq) https://airy.cognipilot.org/cranium/compute/navqplus/setup/#log-in-for-the-first-time ). After flashing the ubuntu image, I change the switches of Navq into eMMC mode (switch 1 off, switch 2 on), and when I screen into the UART connection from the terminal, I get a kernel panic error. It shows in the lines above that is related to ext4-fs. How can i solve the problem?
2,271 次查看
Manuel_Salas
Hello @mmt45
I hope you are doing well.
Could you please contact to your sales person?
We cannot provide support for this board.
Salas.
2,303 次查看
mmt45
Screenshot from 2024-08-19 15-10-21.pngScreenshot from 2024-08-19 15-10-21.png
this is another screenshot from the terminal
