integration refernce example issues
2,825 次查看
ayy24
Hi ,
I downloaded the platform integration example for NXP S32ZSE microprocessor.
1.
Whenever I try to open  the configuration file from that example it shows lot module are not installed for both examples provide in that .
2.
workspace for S32 DS   was missing from that installation directory while it clearly mention in the user manual of that example.
Kindly look in the issue and reply as soon as you get the solution
thanks in advance.
#NXP_Employees#Nxp_tech support
2,811 次查看
lukaszadrapa
Hi Ankit,
I just asked local sales/FAE team to support you directly.
Lukas
