imx8mm frame buffer image display issue
704件の閲覧回数
hyilmaz
Hi, we are using and imx8mm with custom board. We cannot display either kernel logo or an raw image on /dev/fb0. After weston started it kind of configuring display parameters and we are good. We can use display successfully but before weston started we cannot display anything on screen. How can we fix this issue any idea ? We looked into drivers such as drm etc. we cannot see anything to set framebuffer. How can we set framebuffer while kernel booting ? thanks.
680件の閲覧回数
Bio_TICFSL
Look at your console, if there anything missing there, if you are with yocto it got it be working.
regards
