i.MX6ULL - setting u-boot environment variable from userspace
Jamal
Hi All,
We are using i.MX6ULL processor. For setting the uboot environment variables from user space found that we have to add a utility called "u-boot-fw-utils". After adding this when we give fw_printenv command we are encountering issue "Configuration file wrong or corrupted" as mentioned in the screenshot. Also going through some forums in the internet they have suggested to configure the fw_env.cong. Can anyone please let me know what will be the configuration to be added in the fw_env.config file. Also attached the default fw_env.config file.
Jamal Deen
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You can base the implementation in this knowledge base.
