i.MX Quad core processor
1,400 次查看
veena_cm
i.MX6 Quad processor supports 1G Ethernet but in datasheet it is mentioned as it is limited to 470Mbps. Then this device wont support 1G? Please confirm.
1 回复
1,334 次查看
art
From the physical layer point of view, the i.MX6Quad processor supports 1G Ethernet protocol. However, if overall Ethernet data rate is higher than 470Mbps, a data loss may occur.
Artur
