clock on mcxc243
clock on mcxc243
993 次查看
ravicha
how to genrate clock using tpm on mcxc242
is anything need to be done hardware side becouse dev kit is not avaliable
标记 (1)
1 回复
976 次查看
Pablo_Ramos
Hi @ravicha,
You can consult the examples that SDK provides for TPM module.
I recommend you the example tpm_simple_pwm, you should be able to see the PWM on the LED brightness and in the TPM pins on the Arduino headers.
In order to locate the pins that are being used please check the FRDM-MCXC242 Board User Manual
Hope it helps you!
