ask for UJA1131 problem:
1,017 次查看
bozhang
1.i can not restore factory default value, when pull-up CANH to high, CANL&RSTN to low, the pin RXDC no output pulse;
2.after set 74h to 00h, i can not use trace32 to connect debug port with JTAG protocol;
893 次查看
TomasVaverka
Hello Bo,
Sorry about the late response.
Is there any progress on this issue? If not, could you please elaborate a little bit more on the problems you are facing and share with us your schematic/scope shots?
Tomas
