Wireless Charging distance
1,569 次查看
berniecheah
I have a customer planning to use our wireless charging solution. But notice most of the spec is unable to achieve the receiving distance of 15mm. Most of them is around 7-10mm.
Is there any solution that is able to achieve 15mm of receiving distance? In case I might have missed out some..
Or is there any way they are able to achieve this (ie. modifying software or hardware?)
Does not require automotive grade.
标记 (1)
1,489 次查看
guoweisun
