Will RT1170 parallel camera support RAW data
952 次查看
rkumar
Dear sir,
will RT1170 camera parallel CSI interface support RAW format.
and in onput data format what is Generic 10 bit data.
934 次查看
Omar_Anguiano
MIPI-CSI can´t support raw data.
The available data types can be found on chapter 46.3.3 from the reference manual.
Possible workaround is:
Use an ISP convert chip, eg, AP1302, convert the raw to MIPI CSI interface, then connect to RT1170 MIPI CSI. it might be considered by you since this implies adding a component to your solution.
Omar
