What is mpc8313erdb.dtb file.
4,250 次查看
admin
Specialist II
Hi All
I am a newbie in mpc8313erdb reference board.
I wonder what is mpc8313erdb.dtb file uses  in u-boot .
I just know that it is to passed to kernel in u-boot. but I want to edit the file.. how can I..
please recomment web-site or Document...
Please help me, thanks in advance.
Message Edited by newbei on 2008-07-24 12:34 PM
3 回复数
1,584 次查看
genuap
The DTB file is a device tree file. It defines the memory map for the board. From what I can tell, its specific to PowerPC.
http://ozlabs.org/pipermail/linuxppc-dev/2006-April/022164.html
http://ozlabs.org/pipermail/linuxppc-embedded/2007-May/026975.html
1,584 次查看
admin
Specialist II
Thank you for reply.
then. The kernel only need to kown dtb file to know a board devices. such as i2c,PCI,usb, ans so on..
If I change or modify the board device, I only edit the dtb file. isn't it?
Regards, genuap
Message Edited by newbei on 2008-07-24 02:58 PM
1,584 次查看
medina
You need change source of .dtb. You need find .dts in kernel source. :smileywink:
Medina
