Web server on MPC8349E-mITX
2,393件の閲覧回数
dtthang
I don't know how to install a web server on board MPC8349E-mITX, can you show me how to do?
タグ(1)
1,720件の閲覧回数
dtthang
i used LTIB to rebuild a image that selected boa web server,  and then i ran " run tftpramboot " but if this image size over 16MB , it didn't work after reloaded. Do you  known another way to load image beside run command " run tftpramboot" ?
1,720件の閲覧回数
genuap
Do you have the BSP for the mITX board:
http://www.freescale.com/webapp/sps/download/license.jsp?colCode=CWF-MPC8349E-mITX-GP&nodeId=0127260...
In the configuration of the BSP, you can select Boa Web server. Select this. Then rebuild the image, and you'll need to flash a new root filesystem to the board. There should be a document in the BSP that tells you how to do this.
Info on Boa is here:
http://www.boa.org/
 ... Paul
